Ana içeriğe geç
Giriş
Component teardown of Gateway 420GR desktop. This machine originally shipped with Windows XP.
Bu teardown bir tamir kılavuzu değildir. Gateway 420GR cihazınızı onarmak için, servis kılavuzumuzu kullanın.
  1. The left panel of the case has thumbscrews that release the left side from the case.
    • The left panel of the case has thumbscrews that release the left side from the case.
  2. Loosen the first thumbscrew
    • Loosen the first thumbscrew
  3. MacBook Pil Tamir Setleri
    Başlangıç $69.99
    Buy Now
    Başlangıç $69.99
    Buy Now
  4. Loosen the second thumbscrew.
    • Loosen the second thumbscrew.
  5. The side panel will now slide toward the back of the case.
    • The side panel will now slide toward the back of the case.
  6. System RAM
    • System RAM
    • USB headers for front panel USB ports.
    • CMOS battery
  7. Pair one RAM retention clips.  There are two (one on each end) for each of the available slots.
    • Pair one RAM retention clips. There are two (one on each end) for each of the available slots.
    • Pair two RAM retention clips. There are two (one on each end) for each of the available slots.
    • RAM should be paired (same size) and the machine support up to 4GB or RAM as 1GB modules in each of the 4 slots.
    • System supported RAM is 184-pin DIMM DDR PC3200
kyle23
182 İtibar
1 Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 Gün: 0
Son 30 Gün: 6
Her zaman: 2,537
