Ana içeriğe geç
Bu teardown bir tamir kılavuzu değildir. Gateway 420GR cihazınızı onarmak için, servis kılavuzumuzu kullanın.
  1. Repairing Gateway 420GR, Repairing Gateway 420GR: adım 1, 1 resimden 1.
    • The left panel of the case has thumbscrews that release the left side from the case.
  2. Repairing Gateway 420GR: adım 2, 1 resimden 1.
    • Loosen the first thumbscrew
  3. Repairing Gateway 420GR: adım 3, 1 resimden 1.
    • Loosen the second thumbscrew.
  4. Repairing Gateway 420GR: adım 4, 1 resimden 1.
    • The side panel will now slide toward the back of the case.
  5. Repairing Gateway 420GR: adım 5, 1 resimden 1.
    • System RAM
    • USB headers for front panel USB ports.
    • CMOS battery
  6. Repairing Gateway 420GR: adım 6, 1 resimden 1.
    • Pair one RAM retention clips. There are two (one on each end) for each of the available slots.
    • Pair two RAM retention clips. There are two (one on each end) for each of the available slots.
    • RAM should be paired (same size) and the machine support up to 4GB or RAM as 1GB modules in each of the 4 slots.
    • System supported RAM is 184-pin DIMM DDR PC3200
kyle23
182 İtibar
1 Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 12
Her zaman: 3,467
