Neye ihtiyacın var
Bu adım çevrilmemiş. Çevrilmesine yardım edin
The left panel of the case has thumbscrews that release the left side from the case.
The side panel will now slide toward the back of the case.
System RAM
USB headers for front panel USB ports.
CMOS battery
Pair one RAM retention clips. There are two (one on each end) for each of the available slots.
Pair two RAM retention clips. There are two (one on each end) for each of the available slots.
RAM should be paired (same size) and the machine support up to 4GB or RAM as 1GB modules in each of the 4 slots.
System supported RAM is 184-pin DIMM DDR PC3200
