Ana içeriğe geç
Repairing HP OfficeJet 3833 Paper Jam
Neye ihtiyacın var
  1. Repairing HP OfficeJet 3833 Paper Jam, Repairing HP OfficeJet 3833 Paper Jam: adım 1, 2 resimden 1. Repairing HP OfficeJet 3833 Paper Jam, Repairing HP OfficeJet 3833 Paper Jam: adım 1, 2 resimden 2.
    • Remove all paper from the printer.
  2. Repairing HP OfficeJet 3833 Paper Jam: adım 2, 2 resimden 1. Repairing HP OfficeJet 3833 Paper Jam: adım 2, 2 resimden 2.
    • Check the input tray, located in the back of the printer, for any paper remains and remove them.
  3. Repairing HP OfficeJet 3833 Paper Jam: adım 3, 2 resimden 1. Repairing HP OfficeJet 3833 Paper Jam: adım 3, 2 resimden 2.
    Bu adımda kullanılan alet:
    • Check the input tray for any foreign objects.
    • You may need to hold down the input tray and shine a flashlight inside to have a better look.
    • Long tweezers are recommended to remove objects such as thumbnails and tacks.
  4. Repairing HP OfficeJet 3833 Paper Jam: adım 4, 2 resimden 1. Repairing HP OfficeJet 3833 Paper Jam: adım 4, 2 resimden 2.
    • Check the output tray, located in the front of the printer, for paper remains and remove them.
  5. Repairing HP OfficeJet 3833 Paper Jam: adım 5, 3 resimden 1. Repairing HP OfficeJet 3833 Paper Jam: adım 5, 3 resimden 2. Repairing HP OfficeJet 3833 Paper Jam: adım 5, 3 resimden 3.
    • Shut down the printer.
    • Hold down the power button until a message appears.
    • Select the Shut Down option.
    • A message will appear and the printer will turn off.
  6. Repairing HP OfficeJet 3833 Paper Jam: adım 6, 2 resimden 1. Repairing HP OfficeJet 3833 Paper Jam: adım 6, 2 resimden 2.
    • Unplug the printer power cable from the wall outlet.
    • Remove the power cable from the back of the printer.
  7. Repairing HP OfficeJet 3833 Paper Jam: adım 7, 3 resimden 1. Repairing HP OfficeJet 3833 Paper Jam: adım 7, 3 resimden 2. Repairing HP OfficeJet 3833 Paper Jam: adım 7, 3 resimden 3.
    • Pull back on the front sides of the printer to remove the front panel.
    • Then pull the handle inside to remove the ink cartridge panel.
  8. Repairing HP OfficeJet 3833 Paper Jam: adım 8, 2 resimden 1. Repairing HP OfficeJet 3833 Paper Jam: adım 8, 2 resimden 2.
    • Slide the ink cartridge to the side.
    • This step must be done carefully to prevent damage to the printer.
  9. Repairing HP OfficeJet 3833 Paper Jam: adım 9, 2 resimden 1. Repairing HP OfficeJet 3833 Paper Jam: adım 9, 2 resimden 2.
    • Search for and remove any debris.
  10. Repairing HP OfficeJet 3833 Paper Jam: adım 10, 1 resimden 1.
    • Put the printer on its side.
    • You may need to open the top half and lay it down to prevent the printer from falling.
  11. Repairing HP OfficeJet 3833 Paper Jam: adım 11, 2 resimden 1. Repairing HP OfficeJet 3833 Paper Jam: adım 11, 2 resimden 2.
    • Locate the cleanout door on the bottom half of the printer.
    • Open the cleanout door to remove unwanted debris.
Bitiş Çizgisi
Ivory S. Mayorga
193 İtibar
1 Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 14
Son 30 gün: 55
Her zaman: 3,587
