Ana içeriğe geç
Repairing HTC Wildfire S broken screen
Neye ihtiyacın var
  1. Repairing HTC Wildfire S broken screen, broken screen: adım 1, 1 resimden 1.
    • First remove the rear case/battery cover
  2. Repairing HTC Wildfire S broken screen: adım 2, 1 resimden 1.
    • Remove the battery.
    • Remove the two T5 Torx screws.
    • Prise off the lower casing towards the right in the picture, taking care not to break the two tabs
  3. Repairing HTC Wildfire S broken screen: adım 3, 1 resimden 1.
    • Remove the two further T5 torx screws
    • Remove the three Phillips #00 screws.
  4. Repairing HTC Wildfire S broken screen: adım 4, 1 resimden 1.
    • Now carefully prise off the case all round and it will detach completely
  5. Repairing HTC Wildfire S broken screen: adım 5, 1 resimden 1.
    • Prise up this connector
  6. Repairing HTC Wildfire S broken screen: adım 6, 1 resimden 1.
    • And this one
  7. Repairing HTC Wildfire S broken screen: adım 7, 1 resimden 1.
    • Lift up the retainer using a plastic opening tool.
  8. Repairing HTC Wildfire S broken screen: adım 8, 1 resimden 1.
    • And carefully pull out the tab connector.
    • NOW PAUSE WITHOUT MOVING ANYTHING!
  9. Repairing HTC Wildfire S broken screen: adım 9, 1 resimden 1.
    • NOTE THIS FLEXIBLE RIBBON
  10. Repairing HTC Wildfire S broken screen: adım 10, 1 resimden 1.
    • Carefully lift up the board from the left-hand side allowing it to 'hinge' on the metallic ribbon connector you have just noted and allow it to lay flat
    Is this a HTC Wildfire S or Wildfire?
    Andre Quintana - Yanıt
    That's not HTC Wildfire S.
    It's the previous model HTC Wildfire.
    Billy Loizos - Yanıt
    Is this wildfire a 3333 or wildfire s?
    paul - Yanıt
  11. Repairing HTC Wildfire S broken screen: adım 11, 1 resimden 1.
    • The freed connector for the screen should have unfolded
    • Now the screen can be pried from the outer case, but take care as you do so not to tear the metallic ribbon between the two casings
  12. Repairing HTC Wildfire S broken screen: adım 12, 1 resimden 1.
    • To detach the screen it can help to use a pry tool to push the screen from behind through the slot
  13. Repairing HTC Wildfire S broken screen: adım 13, 1 resimden 1.
    • The screen is detached and the connector can be wiggled out through the slot
  14. Repairing HTC Wildfire S broken screen: adım 14, 1 resimden 1.
    • Remove the old screen and connector altogether
  15. Repairing HTC Wildfire S broken screen: adım 15, 1 resimden 1.
    • The connector for the new screen now has to be wiggled back through the slot
  16. Repairing HTC Wildfire S broken screen: adım 16, 1 resimden 1.
    • Once the connecter is pushed through the slot, you should now stick the new screen into place using suitable adhesive strip
  17. Repairing HTC Wildfire S broken screen: adım 17, 1 resimden 1.
    • Fold down the ribbon connector from the screen and carefully fold the two casing halves together again, making sure that the two connectors are sticking out of the side
  18. Repairing HTC Wildfire S broken screen: adım 18, 1 resimden 1.
    • Reconnect the two connectors on the right hand side by pressing down
  19. Repairing HTC Wildfire S broken screen: adım 19, 1 resimden 1.
    • Reinsert the ribbon connector on the left hand side and push down the retaining catch
  20. Repairing HTC Wildfire S broken screen: adım 20, 1 resimden 1.
    • Clip the rear casing back on to the body
  21. Repairing HTC Wildfire S broken screen: adım 21, 1 resimden 1.
    • Put the bottom cover back in place and then replace all the screws
  22. Repairing HTC Wildfire S broken screen: adım 22, 1 resimden 1.
    • Replace battery and battery cover and all should now be well!
Sonuç
8 farklı kişi bu kılavuzu tamamladı.
Mikey Willbiscuit
507 İtibar
1 Kılavuz yazıldı
2 Yorum
Nice detailing of the teardown steps but the phone shown here is a regular HTC Wildfire (HTC G8) and not the latter HTC Wildfire S (HTC G13). Apparently, the orignal Wildfire has two variants (A3333 and A310e). Each variant uses a different digitizer (the touch glass panel on top of the actual LCD). If you need to buy a replacement digitizer, verify if your variant has an IC on the digitizer ribbon cable or not. On my phone, the shattered original digitizer had no IC on the ribbon and when I replaced it with one that had one, the phone wouldn’t recognize the touch inpupts.
Jeremy - Yanıt
Nice! If you wanna recycle any mobile screen you can contact LCD's Buyers
Thanks
shaffy chalana - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 7
Her zaman: 12,120
