Ana içeriğe geç
Repairing Hungry Cat Savings Bank Gear
Neye ihtiyacın var
  1. Repairing Hungry Cat Savings Bank Gear, Repairing Hungry Cat Savings Bank Gear: adım 1, 1 resimden 1.
    • Turn the Hungry Cat Savings Bank off.
    • Using a coin, remove the cap covering the change storage.
    • Use a standard Phillips screwdriver #0 to remove the screw holding the battery cover in place.
  2. Repairing Hungry Cat Savings Bank Gear: adım 2, 1 resimden 1.
    • Empty all change from the Hungry Cat Savings Bank, or it will drive you bonkers during repair.
  3. Repairing Hungry Cat Savings Bank Gear: adım 3, 1 resimden 1.
    • Remove the battery cover and batteries.
  4. Repairing Hungry Cat Savings Bank Gear: adım 4, 1 resimden 1.
    • Remove the four screws holding the cover in place. You'll need a traditional Phillips screwdriver, not a screwdriver set, to reach fully into the wells.
  5. Repairing Hungry Cat Savings Bank Gear: adım 5, 1 resimden 1.
    • Turn over savings bank and slide case up. You might need to grab the base to pull it apart.
  6. Repairing Hungry Cat Savings Bank Gear: adım 6, 1 resimden 1.
    • Locate the jam. You might need to temporarily put in the batteries to activate the arm, so you can find the jam.
  7. Repairing Hungry Cat Savings Bank Gear: adım 7, 1 resimden 1.
    Bu adımda kullanılan alet:
    Satın Al
    • Remove the coin using a set of tweezers.
    • Reassemble the device and enjoy your working Hungry Cat Savings Bank!
Sonuç
To reassemble your device, follow these instructions in reverse order. Make sure to remove the batteries before reassembling.
6 farklı kişi bu kılavuzu tamamladı.
Jeannie Crowley
459 İtibar
2 adet Kılavuz yazıldı
Ekip
Ethical Culture Fieldston School Ethical Culture Fieldston School üyesi
Business
3 Üyeler
6 Yorum
Hi, my motor burned out, where could I get a replacement?
Krill - Yanıt
My one will not stop once it has grabbed a coin , the paw keeps coming out and it has to be turned off at the switch. And he doesn't meow anymore.
michael.tulley - Yanıt
I don’t have my box in front of me, but it sounds like the tray isn’t returning to the rest position fully. When you disassemble it, is there anything preventing the tray (where you put the quarter) from smoothly returning to rest position?
Jeannie Crowley -
How to you repair the Godzilla bank? Bought one yesterday and it completely stopped working?
divineangel1952 - Yanıt
Is there any sound at all coming from the bank or is it completely silent when you press the button?
Jeannie Crowley -
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 10
Son 30 gün: 58
Her zaman: 5,987
