Ana içeriğe geç
Repairing LG 17LX1R LCD Television Power board
Neye ihtiyacın var
  1. Repairing LG 17LX1R LCD Television Power board, Repairing LG 17LX1R LCD Television Power board: adım 1, 3 resimden 1. Repairing LG 17LX1R LCD Television Power board, Repairing LG 17LX1R LCD Television Power board: adım 1, 3 resimden 2. Repairing LG 17LX1R LCD Television Power board, Repairing LG 17LX1R LCD Television Power board: adım 1, 3 resimden 3.
    • This is the LG 17LX1R that will no longer turn on.
    • Remove the cover from the stand by.
    • Press down on the two tabs. The cover should come off easily.
    • Remove the four screws that hold the stand assembly to the chassis.
  2. Repairing LG 17LX1R LCD Television Power board: adım 2, 3 resimden 1. Repairing LG 17LX1R LCD Television Power board: adım 2, 3 resimden 2. Repairing LG 17LX1R LCD Television Power board: adım 2, 3 resimden 3.
    • Remove the four Phillips head screws that attach the stand to the chassis.
    • Remove the eight Phillips screws that hold the back to the chassis. Once the screws are removed, the back will simply snap off.
    • Remove the metal shield. It is fastened with six Phillips screws.
  3. Repairing LG 17LX1R LCD Television Power board: adım 3, 3 resimden 1. Repairing LG 17LX1R LCD Television Power board: adım 3, 3 resimden 2. Repairing LG 17LX1R LCD Television Power board: adım 3, 3 resimden 3.
    • After the shield is removed, the power board and the main board are visible.
    • Power Board
    • Main Board
    • Fuse
    • Check all capacitors for blown tops and/or leakage.
    • Thoroughly inspect the boards. Brown discoloration around Diode D102 is evidence of a short circuit, possibly a blown component.
    • Disconnect all connectors from the power board
    • Remove the four screws that mount the power board to the chassis.
  4. Repairing LG 17LX1R LCD Television Power board: adım 4, 3 resimden 1. Repairing LG 17LX1R LCD Television Power board: adım 4, 3 resimden 2. Repairing LG 17LX1R LCD Television Power board: adım 4, 3 resimden 3.
    • These are the chassis with the power board removed.
    • Discoloration of the back side of the power board is a sign of a faulty diode.
    • Unsolder the diode from the power board.
    • Replacement diode
  5. Repairing LG 17LX1R LCD Television Power board: adım 5, 3 resimden 1. Repairing LG 17LX1R LCD Television Power board: adım 5, 3 resimden 2. Repairing LG 17LX1R LCD Television Power board: adım 5, 3 resimden 3.
    Bu adımda kullanılan alet:
    • Here is the removed diode. Description on the diode reads LT526 IN4007.
    • Solder the new diode onto the power board. Use a pair of tweezers or hemostat to hold the diode in place while soldering.
    • Once the diode is replaced, clean the board with isopropyl alcohol to get rid of any debris or old flux.
    Include many telivisions and user manual
    Raz Media - Yanıt
  6. Repairing LG 17LX1R LCD Television Power board: adım 6, 1 resimden 1.
    • Device powers on and has audio and video after the repair.
Sonuç
38 farklı kişi bu kılavuzu tamamladı.
oldturkey03
814.898 İtibar
119 adet Kılavuz yazıldı
Ekip
Global Fixers Global Fixers üyesi
Community
45 Üyeler
705 adet Kılavuz yazıldı
3Kılavuz Yorumları
Very nice good job
Bhullana - Yanıt
good job my frend
youcef - Yanıt
great idea thats perfect
Joseph Mwangome - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 10
Son 30 gün: 58
Her zaman: 11,452
