Bu kılavuzda güncel değişiklikler var. En son onaylanmamış sürüme geçin.
Giriş
If you find a leak in your door lock system after performing the steps in the vacuum lock system diagnosis guide one of the possible points for leaks is the fuel door lock actuator. Learn to remove it, check it for leaks out of the car, and potentially repair it. If you can't repair it you can install a new one and get your door lock system back to working order.
Neye ihtiyacın var
The gas door lock actuator is accessible in the trunk of the car. Open the trunk, and then pull up the plastic paneling that covers the bottom of the trunk well on the passenger side of the vehicle. The picture shows the well after the panel has been removed.
Look up behind the trunk spring and you'll see the screws that hold the actuator to a panel within the trunk.
Loosen the two Phillips head screws that hold the actuator in place. They do NOT need to be removed fully, just loosened.
Once loosened simply push up on the actuator and then push the screws out through the large holes just above them.
Once loose from the panel pull the actuator out, away from the front of the car and the lock shaft will pull out of the hole where it enters the fuel filler opening.
Disconnect the vacuum "Y" connection from the fuel door lock actuator. At this point you can remove the actuator from the car for inspection.
To test the actuator connect your hand vacuum pump to it and pump up a vacuum of 10 to 15Hg. Note that on this early style actuator there are two connections for vacuum; however, only one is used. The actuator is reversible for mounting on the driver's side of the car. If you connect it and you are unable to pull any vacuum try switching them.
Watch for a vacuum leak. On this actuator there was a very slow leak of about 1Hg a minute. This explains why the system, which had been checked and fixed of all other leaks, was still leaking down overnight.
Since the diaphragm was not torn on this actuator the diaphragm was removed, the actuator and diaphragm were cleaned with mild soap and water, and then the diaphragm was greased with synthetic grease such as dielectric.
Removing this diaphragm is very similar to removing the ones on the early style door lock vacuum actuators. Click here to see that guide for some tips on removing the diaphragm.
Re-install the diaphragm and test the actuator again.
After cleaning and greasing the diaphragm held a solid 16Hg vacuum for several minutes with no change. There must have been some debris under the edge of the diaphragm letting air in slowly. Now that the leak has been fixed it can be re-installed.
If cleaning and greasing the diaphragm does not stop the leaks, or if the diaphragm is visibly cracked or torn, the actuator will need to be replaced with a new or good/tested used actuator.
7 farklı kişi bu kılavuzu tamamladı.
