Ana içeriğe geç
Repairing Minolta Dimage Xt Lens Cover
Neye ihtiyacın var
  1. Repairing Minolta Dimage Xt Lens Cover, Casing: adım 1, 3 resimden 1. Repairing Minolta Dimage Xt Lens Cover, Casing: adım 1, 3 resimden 2. Repairing Minolta Dimage Xt Lens Cover, Casing: adım 1, 3 resimden 3.
    • Locate and remove the silver screws on each side of the camera.
    • Use the Phillips #00 Screwdriver to unscrew all 2.0mm (4 instances) and 4.0mm (2 instances) screws.
  2. Repairing Minolta Dimage Xt Lens Cover: adım 2, 3 resimden 1. Repairing Minolta Dimage Xt Lens Cover: adım 2, 3 resimden 2. Repairing Minolta Dimage Xt Lens Cover: adım 2, 3 resimden 3.
    • Then, carefully pry apart the front and back outer casing away from the internal components.
    • Be aware of the ribbon wire that will disconnect when the casing is detached.
  3. Repairing Minolta Dimage Xt Lens Cover, Lens Cover: adım 3, 1 resimden 1.
    • Place the internal electronics face-up. Look at the side with the flash turned towards you.
    • The lens cover is a small sheet of metal that rests directly infront of the lens when the camera is turned off.
    • Check to see if the spring action arm (what the yellow arrow is pointing to) is attached to the lens cover with the small knob in the corner (circled in yellow).
  4. Repairing Minolta Dimage Xt Lens Cover: adım 4, 1 resimden 1.
    Bu adımda kullanılan alet:
    • If the arm is not attached (as shown in the previous), use tweezers to place the arm over the knob on the lens cover.
    • Inside the yellow circle, the arm is in the correct position.
Sonuç
Reassemble the casing by reversing steps 1 and 2.
Bir başkası bu kılavuzu tamamladı.
Megan Milam
56 İtibar
5 adet Kılavuz yazıldı
Ekip
Clemson, Team 12-4, Benson Spring 2013 Clemson, Team 12-4, Benson Spring 2013 üyesi
CLEM-BENSON-S13S12G4
3 Üyeler
14 adet Kılavuz yazıldı
Bir Yorum
In Bild 3 ist der gelbe Kreis falsch gesetzt: der kleine Knopf ist unten links an der Blende, wie in Bild 4 positioniert. hr
Hubert Rieping - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 5
Son 30 gün: 9
Her zaman: 1,124
