Ana içeriğe geç
Giriş
Use this guide to repair a broken scroll wheel. Be advised, the longevity of your repaired mouse will depend on the strength of the glue or epoxy used in the repair.
Parçalar
Hiçbir parça belirtilmedi.
  1. Slide the tab on the bottom of the mouse to release the top panel. Slide the tab on the bottom of the mouse to release the top panel.
    • Slide the tab on the bottom of the mouse to release the top panel.
  2. Remove the top panel from the mouse. Remove the top panel from the mouse.
    • Remove the top panel from the mouse.
  3. Remove four 7mm Phillips #1 screws.
    • Remove four 7mm Phillips #1 screws.
  4. Use a spudger to pry the upper shell from the mouse at the cord entrance. Move slowly. The upper case is connected to the mouse with delicate wires. Move slowly. The upper case is connected to the mouse with delicate wires.
    • Use a spudger to pry the upper shell from the mouse at the cord entrance.
    • Move slowly. The upper case is connected to the mouse with delicate wires.
  5. Lift the scroll wheel out of the mouse. Lift the scroll wheel out of the mouse.
    • Lift the scroll wheel out of the mouse.
  6. Wiggle the USB cord free of the mouse.
    • Wiggle the USB cord free of the mouse.
    • Resist the temptation to yank the cord free. The wires are very delicate and soldered connections are weak
  7. Remove one 3mm Phillips #1 screw.
    • Remove one 3mm Phillips #1 screw.
    • The quantity and location of screws holding the board to the mouse depends on the manufacture date of this mouse. All screws should be easy to find.
  8. Push the broken axle piece out of the socket. Push the broken axle piece out of the socket. Push the broken axle piece out of the socket.
    • Push the broken axle piece out of the socket.
  9. Glue broken axle piece back onto the scroll wheel. This repair will last only as long as your glue or epoxy holds. The axle will re-break with weak glue and heavy use. My axle survived several heavy use days, just long enough for Monoprice to send me a new mouse.
    • Glue broken axle piece back onto the scroll wheel.
    • This repair will last only as long as your glue or epoxy holds. The axle will re-break with weak glue and heavy use. My axle survived several heavy use days, just long enough for Monoprice to send me a new mouse.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Jeff Snyder
7.475 İtibar
4 adet Kılavuz yazıldı
Takım
iFixit iFixit üyesi
Community
138 Üyeler
16.450 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 5
Her zaman: 645
