Ana içeriğe geç
Repairing Nintendo 64 Controller Joystick Replacement
Neye ihtiyacın var
  1. Repairing Nintendo 64 Controller Joystick Replacement, Controller Joystick Replacement: adım 1, 3 resimden 1. Repairing Nintendo 64 Controller Joystick Replacement, Controller Joystick Replacement: adım 1, 3 resimden 2. Repairing Nintendo 64 Controller Joystick Replacement, Controller Joystick Replacement: adım 1, 3 resimden 3.
    • Begin by removing the 7 #0 Phillips screws from the back of the controller grips as shown.
    • Remove the 2 #00 Phillips screws from the expansion slot
    • Remove the rear housing and set aside.
  2. Repairing Nintendo 64 Controller Joystick Replacement: adım 2, 3 resimden 1. Repairing Nintendo 64 Controller Joystick Replacement: adım 2, 3 resimden 2. Repairing Nintendo 64 Controller Joystick Replacement: adım 2, 3 resimden 3.
    • Gently remove the Z-Button membrane and board by sliding them to the left and pulling out of the joystick assembly.
    • Remove the 3 #00 Phillips screws holding the joystick assembly in place.
  3. Repairing Nintendo 64 Controller Joystick Replacement: adım 3, 3 resimden 1. Repairing Nintendo 64 Controller Joystick Replacement: adım 3, 3 resimden 2. Repairing Nintendo 64 Controller Joystick Replacement: adım 3, 3 resimden 3.
    • Disconnect the joystick data cable and remove the old joystick.
    • To install your new joystick, simply follow these instructions in reverse.
Sonuç
Test out your controller! It should be feeling like new.
33 farklı kişi bu kılavuzu tamamladı.
Zillatron
1.511 İtibar
1 Kılavuz yazıldı
2 Yorum
If you don't line up the z button accurately it can be tricky getting the case back on.
Rainer De Temple - Yanıt
I have a couple thumbstick replacements that do not have the connector. They are from Sodial, and I was wondering if there was a way that they can be easily connected.
derocher1 - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 10
Son 7 gün: 43
Son 30 gün: 189
Her zaman: 44,306
