Giriş
This is a quick guide on replacing a faulty joystick on an N64. If you have a controller with a wobbly joystick, this is the way to resolve your issue.
This can also be considered a mod if you are upgrading the joystick to a redesigned replacement. Upgrading is recommended because the Nintendo 64 has a poorly designed joystick that is prone to breaking and because the redesigned joystick has better control.
Aletler
Parçalar
Begin by removing the 7 #0 Phillips screws from the back of the controller grips as shown.
Remove the 2 #00 Phillips screws from the expansion slot
Remove the rear housing and set aside.
Test out your controller! It should be feeling like new.
32 farklı kişi bu kılavuzu tamamladı.
2 Yorum
If you don't line up the z button accurately it can be tricky getting the case back on.
