Bu sürüm, hatalı düzenlemeler içerebilir. En son doğrulanmış bellek kopyası dönün.
Neye ihtiyacın var
Bu adım çevrilmemiş. Çevrilmesine yardım edin
Begin by removing the 7 #0 Phillips screws from the back of the controller grips as shown.
Remove the 2 #00 Phillips screws from the expansion slot
Remove the rear housing and set aside.
Gently remove the Z-Button membrane and board by sliding them to the left and pulling out of the joystick assembly.
Remove the 3 #00 Phillips screws holding the joystick assembly in place.
Disconnect the joystick data cable and remove the old joystick.
To install your new joystick, simply follow these instructions in reverse.
33 farklı kişi bu kılavuzu tamamladı.
2 Yorum
If you don't line up the z button accurately it can be tricky getting the case back on.
