Bu sürüm, hatalı düzenlemeler içerebilir. En son doğrulanmış bellek kopyası dönün.
Neye ihtiyacın var
Bu adım çevrilmemiş. Çevrilmesine yardım edin
Remove battery
Turn Netbook upside down
Unscrew all screws from the back of the pc
Remove the back plate
Unscrew metal cover on top of fan
Gently lift the fan making sure not to drop dust into the motor of the fan below
Clean fan blades
Clean the fan house
place the fan upside down so the metal pin points upwards
Apply oil
Apply one or two droplets of oil onto the metal pin
Place it on the motor and make sure it rotates without problems
In case there is still sounds coming from the fan when turned on, redo the cleaning and lubrication.
9 farklı kişi bu kılavuzu tamamladı.
