Ana içeriğe geç
Repairing Nokia 6500 Slide LCD
Neye ihtiyacın var
  1. Repairing Nokia 6500 Slide LCD, LCD: adım 1, 3 resimden 1. Repairing Nokia 6500 Slide LCD, LCD: adım 1, 3 resimden 2. Repairing Nokia 6500 Slide LCD, LCD: adım 1, 3 resimden 3.
    • Press the eject button to open battery enclosure. Remove battery, sim card and micro sd card.
  2. Repairing Nokia 6500 Slide LCD: adım 2, 1 resimden 1.
    • Remove four screws using torx 5 screwdriver.
  3. Repairing Nokia 6500 Slide LCD: adım 3, 3 resimden 1. Repairing Nokia 6500 Slide LCD: adım 3, 3 resimden 2. Repairing Nokia 6500 Slide LCD: adım 3, 3 resimden 3.
    • Pry each side evenly around its edges. The phone should start to split into two halves.
  4. Repairing Nokia 6500 Slide LCD: adım 4, 2 resimden 1. Repairing Nokia 6500 Slide LCD: adım 4, 2 resimden 2.
    • The top and bottom half of the phone is still connected by two ribbon connectors each side. Use a thin plastic like a credit card to carefully disconnect it.
  5. Repairing Nokia 6500 Slide LCD: adım 5, 1 resimden 1.
    • Make sure all components stay on each side (see picture).
  6. Repairing Nokia 6500 Slide LCD: adım 6, 2 resimden 1. Repairing Nokia 6500 Slide LCD: adım 6, 2 resimden 2.
    • Pull the black part away from the rest of the phone in the direction shown by the white arrows follows by the blue.
    • This way you can accessing the two screws at the bottom of the phone. Remove four srews using torx 5 screwdriver.
  7. Repairing Nokia 6500 Slide LCD: adım 7, 2 resimden 1. Repairing Nokia 6500 Slide LCD: adım 7, 2 resimden 2.
    • Carefully pry out the lcd cover.
    • Make sure the board connector pass the cover by angle.
  8. Repairing Nokia 6500 Slide LCD: adım 8, 3 resimden 1. Repairing Nokia 6500 Slide LCD: adım 8, 3 resimden 2. Repairing Nokia 6500 Slide LCD: adım 8, 3 resimden 3.
    • Disconnect the LCD connector.
    • Carefully peel the ribbon away from the back of the screen. It's held in place with double sided tape.
    • The LCD screen will now be loose and can be removed and replace with the new one.
Sonuç
Bir başkası bu kılavuzu tamamladı.
dwi
163 İtibar
1 Kılavuz yazıldı
2 Yorum
Great - have screen in. Now, have you ever replaced the port / jack for the charger? Mine will not accept the prong all of a sudden
Brenda Kent - Yanıt
Got new charger port in 2017, now the battery goes - tried several batteries - and tried them in other phones and are fine - thinking something shorting or draining it in the phone?
Brenda Kent - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 3
Son 30 gün: 13
Her zaman: 4,111
