Giriş
Oxycom Cabin 400 uses water to cool down the cabin of a camper, mobile home, or caravan. When the efficiency is low, it can be repaired. This guide will demonstrate how to properly repair your Oxycom Cabin 400.
Neye ihtiyacın var
Switch off the unit and remove the top cover of the Oxycom. There will be 6 screws; remove them.
Apply one drop of Super Glue to the side of the "pipe" on the sprinkler and reinstall it into the white plug by pressing it in. Do the same to all of the loose sprinklers.
There are metal "supports" located inside as well. Put them back in any chosen place. No need to put them under the sprinklers because there are additional round places for them.
Mix 100g of powdered citric acid with 4 liters of warm water.
Pour the solution into the water reservoir.
Start the unit, set it to max cooling and max speed.
After setting to max speed and max cooling press ON/OFF and COOL buttons quickly at the same time and hold for 5 seconds until a beep is heard.
3 farklı kişi bu kılavuzu tamamladı.
