Ana içeriğe geç
Repairing PS4 Bluetooth Antenna from Defect or System fell
Neye ihtiyacın var
  1. Repairing PS4  Bluetooth Antenna from Defect or System fell, Remove the Wi-Fi antenna: adım 1, 2 resimden 1. Repairing PS4  Bluetooth Antenna from Defect or System fell, Remove the Wi-Fi antenna: adım 1, 2 resimden 2.
    • Use the tip of a spudger to disconnect the antenna cable from the motherboard.
    FixBot'a Sor
    Yorum Ekle
  2. Repairing PS4  Bluetooth Antenna from Defect or System fell: adım 2, 3 resimden 1. Repairing PS4  Bluetooth Antenna from Defect or System fell: adım 2, 3 resimden 2. Repairing PS4  Bluetooth Antenna from Defect or System fell: adım 2, 3 resimden 3.
    Bu adımda kullanılan alet:
    • Use a pair of tweezers or your fingers to grab the antenna cable and move it out from the cable guides.
    FixBot'a Sor
    Yorum Ekle
  3. Repairing PS4  Bluetooth Antenna from Defect or System fell: adım 3, 3 resimden 1. Repairing PS4  Bluetooth Antenna from Defect or System fell: adım 3, 3 resimden 2. Repairing PS4  Bluetooth Antenna from Defect or System fell: adım 3, 3 resimden 3.
    • Use a pair of tweezers or your fingers to thread the antenna cable out from underneath the optical drive cable.
    FixBot'a Sor
    Yorum Ekle
  4. Repairing PS4  Bluetooth Antenna from Defect or System fell: adım 4, 2 resimden 1. Repairing PS4  Bluetooth Antenna from Defect or System fell: adım 4, 2 resimden 2.
    • Remove the 9.7 mm Torx security screw securing the antenna.
    FixBot'a Sor
    Yorum Ekle
  5. Repairing PS4  Bluetooth Antenna from Defect or System fell: adım 5, 2 resimden 1. Repairing PS4  Bluetooth Antenna from Defect or System fell: adım 5, 2 resimden 2.
    • Remove the Wi-Fi antenna.
    FixBot'a Sor
    Yorum Ekle
  6. Repairing PS4  Bluetooth Antenna from Defect or System fell, What is Wrong?: adım 6, 1 resimden 1.
    • As you can see there are 2 solder points . the wire must run through the first point to the second point. But when the system fell it broke that connection and Antenna got bent. If at factory the solder points were not correct it will cause the same lag issue with controller and WiFi.
    FixBot'a Sor
    Yorum Ekle
  7. Repairing PS4  Bluetooth Antenna from Defect or System fell, Solder it back: adım 7, 1 resimden 1.
    • This is the easy part. Remove the antenna. Move the wire inbetween the two solder points so it is connecting to the second point. Once there take your soldering Iron and heat up the solder and drag it over the wire to make the connection.
    FixBot'a Sor
    Yorum Ekle
    • Just remember to leave the gap here. Do not bend the antenna to make the points touch your self. The gap that runs through it is there by design and changing that has adverse effects on controller and WiFi . But its that easy. My PS4 now works fine with controller and WiFi . No need for further tear-down and extra parts. Put bottom on. GTGo
    FixBot'a Sor
    Yorum Ekle
Sonuç
39 farklı kişi bu kılavuzu tamamladı.
bdcallen69
1.239 İtibar
1 Kılavuz yazıldı
41Kılavuz Yorumları
My console was giving me the same problem aft lots of research i came across ur guide and today i fixed the wifi antenna and its working awesome Thanks alot
Muzaffar - Yanıt Paylaş
Me podrías compartir la guía?
JasonJam21 Dc - Yanıt Paylaş
Could you share the guide?
I've run into a similar problem (PS4 won't recognize controllers) but wifi works fine. Is it possible that bluetooth doesn't work but wifi does?
gustavo - Yanıt Paylaş
I replaced my antenna with a new one. But im still experiencing input lag. What else should I do?
angellom90 - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 19
Son 7 gün: 89
Son 30 gün: 434
Her zaman: 208,050
