Ana içeriğe geç
Repairing Paper Jam
  1. Repairing Paper Jam, Drum Unit and Toner Cartridge: adım 1, 1 resimden 1.
    • Press the front cover release button.
    • Keep the button pressed and pull the cover toward yourself.
  2. Repairing Paper Jam: adım 2, 3 resimden 1. Repairing Paper Jam: adım 2, 3 resimden 2. Repairing Paper Jam: adım 2, 3 resimden 3.
    • With the front cover in the downward position, the drum & toner unit will be visible.
    • Grab the black-and-yellow handle on the unit. Lift unit up and pull it out of the printer.
  3. Repairing Paper Jam, Repairing Paper Jam: adım 3, 2 resimden 1. Repairing Paper Jam, Repairing Paper Jam: adım 3, 2 resimden 2.
    • DO NOT TOUCH the electrodes on the right inner wall of the printer. Touching these electrodes can cause electrical damage to the printer.
  4. Repairing Paper Jam, Paper Jam Type 1: adım 4, 3 resimden 1. Repairing Paper Jam, Paper Jam Type 1: adım 4, 3 resimden 2. Repairing Paper Jam, Paper Jam Type 1: adım 4, 3 resimden 3.
    • If jammed, paper will be visible after removing the drum unit. To clear paper jam, reach into printer and grab a corner of the paper.
    • Proceed to lift paper up and out of the printer.
    • Jammed paper may require an excess amount of force to be removed from printer.
  5. Repairing Paper Jam, Paper Jam Type 2: adım 5, 2 resimden 1. Repairing Paper Jam, Paper Jam Type 2: adım 5, 2 resimden 2.
    • Grab onto the lift located on the paper tray near the bottom on the front of the printer.
    • Pull the paper tray completely out of the printer by pulling towards yourself.
  6. Repairing Paper Jam: adım 6, 2 resimden 1. Repairing Paper Jam: adım 6, 2 resimden 2.
    • If jammed paper is visible, grab onto the paper and remove by pulling up and towards yourself.
    • Jammed paper may require a large amount of force to be removed from printer.
  7. Repairing Paper Jam, Paper Jam Type 3: adım 7, 3 resimden 1. Repairing Paper Jam, Paper Jam Type 3: adım 7, 3 resimden 2. Repairing Paper Jam, Paper Jam Type 3: adım 7, 3 resimden 3.
    • Located on the back of the printer, open up the cover by grabbing onto the tab and pulling down.
  8. Repairing Paper Jam: adım 8, 3 resimden 1. Repairing Paper Jam: adım 8, 3 resimden 2. Repairing Paper Jam: adım 8, 3 resimden 3.
    • In front of you will see two blue tabs, one on the left and right side.
    • First, push the top part of the tab in until the bottom part of the tab lifts up.
    • Grab onto the bottom part of the tab.
  9. Repairing Paper Jam: adım 9, 2 resimden 1. Repairing Paper Jam: adım 9, 2 resimden 2.
    • Once you have a firm grib of both the right and left tab, lift both tabs up and towards yourself.
    • The fuser cover, which the tabs are connected to, does not come completely out of the printer because it is attached to the bottom by a hinge.
  10. Repairing Paper Jam: adım 10, 3 resimden 1. Repairing Paper Jam: adım 10, 3 resimden 2. Repairing Paper Jam: adım 10, 3 resimden 3.
    • If jammed paper is visible, grab onto the top of the paper and pull up until completely removed from printer.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Nathan Ruiz
165 İtibar
2 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 4-14, Forte Winter 2010 Cal Poly, Team 4-14, Forte Winter 2010 üyesi
CPSU-FORTE-W10S4G14
5 Üyeler
10 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 5
Son 30 gün: 24
Her zaman: 13,995
