Ana içeriğe geç
Repairing Paper Jam
  1. Repairing Paper Jam, Drum Unit and Toner Cartridge: adım 1, 1 resimden 1.
    • Press the front cover release button.
    • Keep the button pressed and pull the cover toward yourself.
    FixBot'a Sor
    Yorum Ekle
  2. Repairing Paper Jam: adım 2, 3 resimden 1. Repairing Paper Jam: adım 2, 3 resimden 2. Repairing Paper Jam: adım 2, 3 resimden 3.
    • With the front cover in the downward position, the drum & toner unit will be visible.
    • Grab the black-and-yellow handle on the unit. Lift unit up and pull it out of the printer.
    FixBot'a Sor
    Yorum Ekle
  3. Repairing Paper Jam, Repairing Paper Jam: adım 3, 2 resimden 1. Repairing Paper Jam, Repairing Paper Jam: adım 3, 2 resimden 2.
    • DO NOT TOUCH the electrodes on the right inner wall of the printer. Touching these electrodes can cause electrical damage to the printer.
    FixBot'a Sor
    Yorum Ekle
  4. Repairing Paper Jam, Paper Jam Type 1: adım 4, 3 resimden 1. Repairing Paper Jam, Paper Jam Type 1: adım 4, 3 resimden 2. Repairing Paper Jam, Paper Jam Type 1: adım 4, 3 resimden 3.
    • If jammed, paper will be visible after removing the drum unit. To clear paper jam, reach into printer and grab a corner of the paper.
    • Proceed to lift paper up and out of the printer.
    • Jammed paper may require an excess amount of force to be removed from printer.
    FixBot'a Sor
    Yorum Ekle
  5. Repairing Paper Jam, Paper Jam Type 2: adım 5, 2 resimden 1. Repairing Paper Jam, Paper Jam Type 2: adım 5, 2 resimden 2.
    • Grab onto the lift located on the paper tray near the bottom on the front of the printer.
    • Pull the paper tray completely out of the printer by pulling towards yourself.
    FixBot'a Sor
    Yorum Ekle
  6. Repairing Paper Jam: adım 6, 2 resimden 1. Repairing Paper Jam: adım 6, 2 resimden 2.
    • If jammed paper is visible, grab onto the paper and remove by pulling up and towards yourself.
    • Jammed paper may require a large amount of force to be removed from printer.
    FixBot'a Sor
    Yorum Ekle
  7. Repairing Paper Jam, Paper Jam Type 3: adım 7, 3 resimden 1. Repairing Paper Jam, Paper Jam Type 3: adım 7, 3 resimden 2. Repairing Paper Jam, Paper Jam Type 3: adım 7, 3 resimden 3.
    • Located on the back of the printer, open up the cover by grabbing onto the tab and pulling down.
    FixBot'a Sor
    Yorum Ekle
  8. Repairing Paper Jam: adım 8, 3 resimden 1. Repairing Paper Jam: adım 8, 3 resimden 2. Repairing Paper Jam: adım 8, 3 resimden 3.
    • In front of you will see two blue tabs, one on the left and right side.
    • First, push the top part of the tab in until the bottom part of the tab lifts up.
    • Grab onto the bottom part of the tab.
    FixBot'a Sor
    Yorum Ekle
  9. Repairing Paper Jam: adım 9, 2 resimden 1. Repairing Paper Jam: adım 9, 2 resimden 2.
    • Once you have a firm grib of both the right and left tab, lift both tabs up and towards yourself.
    • The fuser cover, which the tabs are connected to, does not come completely out of the printer because it is attached to the bottom by a hinge.
    FixBot'a Sor
    Yorum Ekle
  10. Repairing Paper Jam: adım 10, 3 resimden 1. Repairing Paper Jam: adım 10, 3 resimden 2. Repairing Paper Jam: adım 10, 3 resimden 3.
    • If jammed paper is visible, grab onto the top of the paper and pull up until completely removed from printer.
    FixBot'a Sor
    Yorum Ekle
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Nathan Ruiz
186 İtibar
2 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 4-14, Forte Winter 2010 Cal Poly, Team 4-14, Forte Winter 2010 üyesi
CPSU-FORTE-W10S4G14
5 Üyeler
10 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 13
Son 30 gün: 79
Her zaman: 15,152
