Ana içeriğe geç
Repairing Polaroid One-Step 600 Shutter
Neye ihtiyacın var
  1. Repairing Polaroid One-Step 600 Shutter, Repairing Polaroid One-Step 600 Shutter: adım 1, 3 resimden 1. Repairing Polaroid One-Step 600 Shutter, Repairing Polaroid One-Step 600 Shutter: adım 1, 3 resimden 2. Repairing Polaroid One-Step 600 Shutter, Repairing Polaroid One-Step 600 Shutter: adım 1, 3 resimden 3.
    • THIS REPAIR GUIDE IS VERY DIFFICULT AND SHOULD ONLY BE FOLLOWED IF YOU HAVE EXPERT MECHANICAL EXPERIENCE.
    • Open the flash/ lens compartment of the Polaroid camera to a 30 degree angle with the horizontal.
  2. Repairing Polaroid One-Step 600 Shutter: adım 2, 3 resimden 1. Repairing Polaroid One-Step 600 Shutter: adım 2, 3 resimden 2. Repairing Polaroid One-Step 600 Shutter: adım 2, 3 resimden 3.
    • Separate the flash section of the camera from the main body by unhooking the sides.
    • BE CAREFUL NOT TO YANK THE TWO SECTIONS APART BECAUSE THE BAND WIRE STILL ATTACHES THEM!
  3. Repairing Polaroid One-Step 600 Shutter: adım 3, 1 resimden 1.
    • Open the battery/ cartridge compartment fully.
  4. Repairing Polaroid One-Step 600 Shutter: adım 4, 3 resimden 1. Repairing Polaroid One-Step 600 Shutter: adım 4, 3 resimden 2. Repairing Polaroid One-Step 600 Shutter: adım 4, 3 resimden 3.
    • Insert spudger in between face of camera and sides where the four tabs are located.
  5. Repairing Polaroid One-Step 600 Shutter: adım 5, 2 resimden 1. Repairing Polaroid One-Step 600 Shutter: adım 5, 2 resimden 2.
    • Once tabs are released, pull face of camera straight out.
  6. Repairing Polaroid One-Step 600 Shutter: adım 6, 1 resimden 1.
    • Carefully use tweezers to remove the spring from the hooks.
    • CAUTION: You may lose the spring if it pops off the hooks.
  7. Repairing Polaroid One-Step 600 Shutter: adım 7, 2 resimden 1. Repairing Polaroid One-Step 600 Shutter: adım 7, 2 resimden 2.
    • Use the spudger to release the latch for the shutter mechanism.
    • Rotate the shutter mechanism clockwise until it stops.
    • If latch was successfully released, shutter mechanism should touch top plastic brace.
  8. Repairing Polaroid One-Step 600 Shutter: adım 8, 3 resimden 1. Repairing Polaroid One-Step 600 Shutter: adım 8, 3 resimden 2. Repairing Polaroid One-Step 600 Shutter: adım 8, 3 resimden 3.
    • Release the two tabs that hold lens plate in position.
  9. Repairing Polaroid One-Step 600 Shutter: adım 9, 1 resimden 1.
    • Remove the lens plate by pulling down, then away from the camera.
  10. Repairing Polaroid One-Step 600 Shutter: adım 10, 3 resimden 1. Repairing Polaroid One-Step 600 Shutter: adım 10, 3 resimden 2. Repairing Polaroid One-Step 600 Shutter: adım 10, 3 resimden 3.
    • Remove the shutter mechanism from the camera.
    • Remove black latch piece from the camera.
    • Remove shutter plates from the camera.
  11. Repairing Polaroid One-Step 600 Shutter: adım 11, 3 resimden 1. Repairing Polaroid One-Step 600 Shutter: adım 11, 3 resimden 2. Repairing Polaroid One-Step 600 Shutter: adım 11, 3 resimden 3.
    • To replace the shutter pieces in the camera, first make sure they are in the proper order.
    • The shutter piece at the bottom of the first picture belongs on the bottom.
    • The shutter piece in the middle of the first picture goes in the middle (second picture).
    • The shutter piece at the top of the first picture goes on top (third picture).
  12. Repairing Polaroid One-Step 600 Shutter: adım 12, 3 resimden 1. Repairing Polaroid One-Step 600 Shutter: adım 12, 3 resimden 2. Repairing Polaroid One-Step 600 Shutter: adım 12, 3 resimden 3.
    • By looking at the first picture, line up the long, skinny slots on the three shutter pieces.
    • In the second picture, notice the pin inside the circle.
    • Line up the slots in the shutters with the pin inside the camera as shown in the third picture.
  13. Repairing Polaroid One-Step 600 Shutter: adım 13, 3 resimden 1. Repairing Polaroid One-Step 600 Shutter: adım 13, 3 resimden 2. Repairing Polaroid One-Step 600 Shutter: adım 13, 3 resimden 3.
    • NOTE: The shutter pieces are not included in the first two pictures of this step because they slide around too easily for us to take pictures with them in the camera.
    • Put black plastic piece back into camera, making sure to slide tab into slot (rectangle) and onto the pin (circle).
    • Final assembly for this step should look like the third picture.
  14. Repairing Polaroid One-Step 600 Shutter: adım 14, 2 resimden 1. Repairing Polaroid One-Step 600 Shutter: adım 14, 2 resimden 2.
    • CAUTION: The next two steps are incredibly difficult!
    • First, you must align the tab (circled) with the slot (rectangle).
    • Do not put pieces together until after reading the next step!!!
  15. Repairing Polaroid One-Step 600 Shutter: adım 15, 3 resimden 1. Repairing Polaroid One-Step 600 Shutter: adım 15, 3 resimden 2. Repairing Polaroid One-Step 600 Shutter: adım 15, 3 resimden 3.
    • REMINDER: This step is very difficult and may require multiple attempts.
    • Align teal and orange circled tabs from the first picture with the respective teal and orange holes in the shutter pieces.
    • After the shutter mechanism is placed into the camera, make sure all three shutter pieces are attached correctly.
    • NOTE: When correctly attached, the shutter pieces will slide in opposite directions when the shutter mechanism is rotated.
    • To finish putting the Polaroid back together, follow steps 9 through 1 in reverse.
Bitiş Çizgisi
7 farklı kişi bu kılavuzu tamamladı.
Kimberly
185 İtibar
1 Kılavuz yazıldı
Ekip
Cal Poly, Team 16-31, Maness Winter 2010 Cal Poly, Team 16-31, Maness Winter 2010 üyesi
CPSU-MANESS-W10S16G31
4 Üyeler
6 adet Kılavuz yazıldı
Bir Yorum
I'm pretty sure every type 600 polaroid camera is built the same so this should work with other 600 cameras. I followed this guide for my polaroid 640 land camera and it was exactly the same.
Camdyn - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 6
Son 7 gün: 33
Son 30 gün: 116
Her zaman: 33,603
