Ana içeriğe geç
Repairing Quasar Microwave Door Handle
Neye ihtiyacın var
    1. Repairing Quasar Microwave Door Handle, Disassembling Quasar Microwave Outer Cover: adım 1, 1 resimden 1.
      • Disconnect the power supply cord from the outlet.
      FixBot'a Sor
      Yorum Ekle
    2. Repairing Quasar Microwave Door Handle: adım 2, 2 resimden 1. Repairing Quasar Microwave Door Handle: adım 2, 2 resimden 2.
      • Remove the eight screws holding the wood-patterned cover to the microwave frame.
      • The first four screws are located on either side of the microwave front.
      FixBot'a Sor
      Yorum Ekle
    3. Repairing Quasar Microwave Door Handle: adım 3, 2 resimden 1. Repairing Quasar Microwave Door Handle: adım 3, 2 resimden 2.
      • Remove the additional four screws securing the wood-paneled case to the microwave frame.
      FixBot'a Sor
      Yorum Ekle
    4. Repairing Quasar Microwave Door Handle: adım 4, 3 resimden 1. Repairing Quasar Microwave Door Handle: adım 4, 3 resimden 2. Repairing Quasar Microwave Door Handle: adım 4, 3 resimden 3.
      • Placing your hands on either side of the case, slide the case back gently until you feel it completely separate from the microwave frame.
      • Lift the case upward slowly until the case is free of the microwave.
      FixBot'a Sor
      Yorum Ekle
    1. Repairing Quasar Microwave Door Handle, Repairing Quasar Microwave Door Handle: adım 5, 2 resimden 1. Repairing Quasar Microwave Door Handle, Repairing Quasar Microwave Door Handle: adım 5, 2 resimden 2.
      • Observe the lever mechanism found just behind the door handle, inside the microwave.
      • The plastic lever should be above the metal lever. If the metal lever is above the plastic lever, this is why the door will not open.
      • In this picture, the metal part is ABOVE the white plastic part. The white part needs to be lifted to open the door so when the door lever is pressed, the metal part rises, and the plastic part stays in place.
      FixBot'a Sor
      Yorum Ekle
    2. Repairing Quasar Microwave Door Handle: adım 6, 3 resimden 1. Repairing Quasar Microwave Door Handle: adım 6, 3 resimden 2. Repairing Quasar Microwave Door Handle: adım 6, 3 resimden 3.
      • Lift up on the outside lever.
      • Push up on the white plastic piece.
      • Push metal bar down, snapping the white plastic piece above it.
      FixBot'a Sor
      Yorum Ekle
    3. Repairing Quasar Microwave Door Handle: adım 7, 2 resimden 1. Repairing Quasar Microwave Door Handle: adım 7, 2 resimden 2.
      • This is how the fixed mechanism should look.
      • Press the button and enjoy your newly fixed door!
      FixBot'a Sor
      Yorum Ekle
Sonuç
Bir başkası bu kılavuzu tamamladı.
Samuel
142 İtibar
2 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 2-12, Propen Fall 2012 Cal Poly, Team 2-12, Propen Fall 2012 üyesi
CPSU-PROPEN-F12S2G12
3 Üyeler
18 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 7
Son 30 gün: 35
Her zaman: 2,694
