Ana içeriğe geç
Repairing Quasar Microwave Fan
Neye ihtiyacın var
  1. Repairing Quasar Microwave Fan, Disassembling Quasar Microwave Outer Cover: adım 1, 1 resimden 1.
    • Disconnect the power supply cord from the outlet.
  2. Repairing Quasar Microwave Fan: adım 2, 2 resimden 1. Repairing Quasar Microwave Fan: adım 2, 2 resimden 2.
    • Remove the eight screws holding the wood-patterned cover to the microwave frame.
    • The first four screws are located on either side of the microwave front.
  3. Repairing Quasar Microwave Fan: adım 3, 2 resimden 1. Repairing Quasar Microwave Fan: adım 3, 2 resimden 2.
    • Remove the additional four screws securing the wood-paneled case to the microwave frame.
  4. Repairing Quasar Microwave Fan: adım 4, 3 resimden 1. Repairing Quasar Microwave Fan: adım 4, 3 resimden 2. Repairing Quasar Microwave Fan: adım 4, 3 resimden 3.
    • Placing your hands on either side of the case, slide the case back gently until you feel it completely separate from the microwave frame.
    • Lift the case upward slowly until the case is free of the microwave.
  5. Repairing Quasar Microwave Fan, Repairing Quasar Microwave Fan: adım 5, 2 resimden 1. Repairing Quasar Microwave Fan, Repairing Quasar Microwave Fan: adım 5, 2 resimden 2.
    • Locate the fan in the newly exposed interior.
    • Try spinning the fan with your finger. If it spins freely, the fan is not jammed.
    • If the fan does not spin freely, locate what is jamming the fan and remove it.
  6. Repairing Quasar Microwave Fan: adım 6, 1 resimden 1.
    • If the fan is not jammed yet still does not work, check that there are no disconnected wires, especially to the fan.
    • In order to work properly, there should be two wires going in and out of the fan. If you are missing either of these wires, locate the loose wire/s and connect them.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Melanie
107 İtibar
2 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 2-12, Propen Fall 2012 Cal Poly, Team 2-12, Propen Fall 2012 üyesi
CPSU-PROPEN-F12S2G12
3 Üyeler
6 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 13
Her zaman: 1,591
