Ana içeriğe geç
Revlon 473 Hair Dryer Switch Replacement
Neye ihtiyacın var
  1. Revlon 473 Hair Dryer Switch Replacement, Shell: adım 1, 1 resimden 1.
    • Before disassembly, make sure that the device is unplugged.
    • Remove the two 17.83 mm black screws located on the handle.
  2. Revlon 473 Hair Dryer Switch Replacement: adım 2, 1 resimden 1.
    • Separate the shell from the main component.
    • Check to ensure each piece is free from debris.
  3. Revlon 473 Hair Dryer Switch Replacement: adım 3, 3 resimden 1. Revlon 473 Hair Dryer Switch Replacement: adım 3, 3 resimden 2. Revlon 473 Hair Dryer Switch Replacement: adım 3, 3 resimden 3.
    • Remove the casing from the heating element.
    • For reassembly, reattach the silver casing before the black cover.
  4. Revlon 473 Hair Dryer Switch Replacement, Switch: adım 4, 1 resimden 1.
    • Locate the two switches in the handle of the device.
  5. Revlon 473 Hair Dryer Switch Replacement: adım 5, 1 resimden 1.
    • Set the multimeter to 200 ACV.
  6. Revlon 473 Hair Dryer Switch Replacement: adım 6, 1 resimden 1.
    • Bring the probes toward each switch to test for continuity.
    • If the numbers on the multimeter continue to change, the circuit is closed and the switches are functioning.
    • If the meter stays at a set number, the circuit is open, and the switch needs to be replaced.
    • To replace a faulty switch, cut the wires and solder the wires back on to the new switch.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Jessica Leyva
143 İtibar
5 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 1-5, Propen Fall 2012 Cal Poly, Team 1-5, Propen Fall 2012 üyesi
CPSU-PROPEN-F12S1G5
3 Üyeler
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 11
Son 30 gün: 30
Her zaman: 1,817
