Giriş
The track pad on this model of Chromebooks is known to stop "clicking" when compressed. This is due to the cover of the track pad rubbing against the Chromebook casing. Removing the cover and re-positioning it can solve this issue.
Neye ihtiyacın var
Place the iOpener or another type of heating bag, in the microwave for 1 minute.
Remove and press on the track pad for 1 -2 minutes as to loosen the adhesive.
Apply pressure to the the bottom of the Chromebook under the track pad.
Using a fingernail, or other small prying tool, separate the plastic covering from the track pad board.
Completely remove the cover from the track pad board.
Press on the track pad board in order to verify that it still clicks.
Reapply the cover to the track pad board starting from the top.
Be sure to leave a slight gap between the cover and casing on all sides when reapplying.
Finish applying the track pad cover and firmly press it to the track pad board.
Ensure that the track pad still clicks, if it does not, remove the cover, adjust the positioning, and reapply.
10 farklı kişi bu kılavuzu tamamladı.
7 Yorum
I did it, awkwardly using an excessively large gel heating pad to loosen the cover, and then prying it off.
I think the best advice in replacing the cover is to position the edge of the cover flush with the edge of the surrounding casing that is near the keyboard, leaving a slight but visible gap between the cover and the edge of the surrounding casing that is away from the keyboard. The latter gap ensures that the casing won't prevent the cover from moving and clicking the button underneath. (I don't think any gap at the edge near the keyboard is necessary, since the button that has to be clicked is far from that edge.)
I just realized you don't need to actually remove the plastic track pad cover. Once it is heated you can just push it towards the keys. That will free it up enough to "click" again. I also use a small piece of tape to hold it in place while the glue dries. I tape it so that it is putting pressure towards the keys.
