Ana içeriğe geç
Repairing Tire Hole/Puncture
Neye ihtiyacın var
  1. Repairing Tire Hole/Puncture, Repairing Tire Hole/Puncture: adım 1, 1 resimden 1.
    • Wipe the surface of the tire with a rag to remove any loose dirt, rocks, or debris.
  2. Repairing Tire Hole/Puncture: adım 2, 1 resimden 1.
    • Using the air compressor, air the tire up to the original recommended weight for the vehicle.
    • Air is expected to continue to leak out so do not worry if you cannot get it perfect.
  3. Repairing Tire Hole/Puncture: adım 3, 2 resimden 1. Repairing Tire Hole/Puncture: adım 3, 2 resimden 2.
    • Use the air pressure gauge to make sure the tire is now aired up to its original pressure.
  4. Repairing Tire Hole/Puncture: adım 4, 1 resimden 1.
    • Spray the surface of the tire completely with the soapy water.
  5. Repairing Tire Hole/Puncture: adım 5, 1 resimden 1.
    • Look for tiny air bubbles forming from the leaking air and soap combination, this is where the hole is located.
  6. Repairing Tire Hole/Puncture: adım 6, 3 resimden 1. Repairing Tire Hole/Puncture: adım 6, 3 resimden 2. Repairing Tire Hole/Puncture: adım 6, 3 resimden 3.
    • Once the hole is located, remove any foreign objects with the pliers if present.
    • Any object that is stuck in the tire, or puncturing the tire is considered a foreign object. These may include sharp objects, commonly seen as nails, screws, or pieces of metal.
  7. Repairing Tire Hole/Puncture: adım 7, 1 resimden 1.
    • Insert the reamer into the puncture.
    • Work the reamer in and out while twisting to clean and prep the puncture.
  8. Repairing Tire Hole/Puncture: adım 8, 1 resimden 1.
    • Put the plug into the insertion tool.
  9. Repairing Tire Hole/Puncture: adım 9, 1 resimden 1.
    • Insert the plug into the punctured area, leaving about ¼ inch of the plug above the surface of the tire.
    • Yank the insertion tool so the plug remains in the tire, but the tool releases.
    • Cut the remaining plug so it is flush with the tire.
  10. Repairing Tire Hole/Puncture: adım 10, 1 resimden 1.
    • Refill the tire to the proper pressure.
  11. Repairing Tire Hole/Puncture: adım 11, 2 resimden 1. Repairing Tire Hole/Puncture: adım 11, 2 resimden 2.
    • Use the air pressure gauge to make sure that the tire is back to its original air pressure.
Sonuç
4 farklı kişi bu kılavuzu tamamladı.
Jaylynn Hoffman
266 İtibar
1 Kılavuz yazıldı
Bir Yorum
i work at discount tire and this is not a department of transportation approved fix and and repuidiple tire dealer will tell you they cannot put a tire back on if they notice this
redheadmateo - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 13
Son 30 gün: 81
Her zaman: 5,602
