Ana içeriğe geç
Eşyalarını Tamir Et
Onarma Hakkı
Mağaza
Giriş
Learn how to stop the buzzing and bring back clear sound on your headset.
Parçalar
Hiçbir parça belirtilmedi.
  1. Remove the cushion of the speaker that the buzzing noise is occurring. Remove the cushion of the speaker that the buzzing noise is occurring.
    • Remove the cushion of the speaker that the buzzing noise is occurring.
  2. Use the Philips PH00 screwdriver to unscrew the four screws located on the inner part of the rail adjustment. Use the Philips PH00 screwdriver to unscrew the four screws located on the inner part of the rail adjustment. Use the Philips PH00 screwdriver to unscrew the four screws located on the inner part of the rail adjustment.
    • Use the Philips PH00 screwdriver to unscrew the four screws located on the inner part of the rail adjustment.
  3. Remove the black metal bracket by unscrewing the two screws connecting it to the railing. Remove the black metal bracket by unscrewing the two screws connecting it to the railing.
    • Remove the black metal bracket by unscrewing the two screws connecting it to the railing.
  4. Unscrew the screws in the locations shown to remove the speaker cover. Unscrew the screws in the locations shown to remove the speaker cover.
    • Unscrew the screws in the locations shown to remove the speaker cover.
  5. Place the black cover to the side, near the rest of the setup.
    • Place the black cover to the side, near the rest of the setup.
  6. Observe the wire orientation: The red metal wire should be to the far left, while the green metal wire should be next to it, the skinny red rubber wire should be second to the right, and the thick red rubber wire should be to the far right. If any of the wires are out of place fasten them into their proper positions. Observe the wire orientation: The red metal wire should be to the far left, while the green metal wire should be next to it, the skinny red rubber wire should be second to the right, and the thick red rubber wire should be to the far right. If any of the wires are out of place fasten them into their proper positions.
    • Observe the wire orientation: The red metal wire should be to the far left, while the green metal wire should be next to it, the skinny red rubber wire should be second to the right, and the thick red rubber wire should be to the far right. If any of the wires are out of place fasten them into their proper positions.
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Essien Benjamin
166 İtibar
1 Kılavuz yazıldı
Takım
UMass Dartmouth, Team 3-3, Duarte Spring 2015 UMass Dartmouth, Team 3-3, Duarte Spring 2015 üyesi
UMASSD-DUARTE-S15S3G3
4 Üyeler
5 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 0
Her zaman: 2,050
