Ana içeriğe geç
Repairing VTech Touch and Swipe Baby Phone Screen Alignment
Neye ihtiyacın var
    1. Repairing VTech Touch and Swipe Baby Phone Screen Alignment, Battery: adım 1, 2 resimden 1. Repairing VTech Touch and Swipe Baby Phone Screen Alignment, Battery: adım 1, 2 resimden 2.
      • Using a Phillips #1 screwdriver, remove the 4.8mm screw on the battery cover by twisting the screwdriver counter-clockwise.
      FixBot'a Sor
      Yorum Ekle
    2. Repairing VTech Touch and Swipe Baby Phone Screen Alignment: adım 2, 3 resimden 1. Repairing VTech Touch and Swipe Baby Phone Screen Alignment: adım 2, 3 resimden 2. Repairing VTech Touch and Swipe Baby Phone Screen Alignment: adım 2, 3 resimden 3.
      • Remove the two AAA batteries by pulling on one end of the battery and lifting it straight out.
      FixBot'a Sor
      Yorum Ekle
    3. Repairing VTech Touch and Swipe Baby Phone Screen Alignment: adım 3, 3 resimden 1. Repairing VTech Touch and Swipe Baby Phone Screen Alignment: adım 3, 3 resimden 2. Repairing VTech Touch and Swipe Baby Phone Screen Alignment: adım 3, 3 resimden 3.
      • When reassembling, align the notch on the battery panel with the slot on the phone.
      FixBot'a Sor
      Yorum Ekle
    1. Repairing VTech Touch and Swipe Baby Phone Screen Alignment, Repairing VTech Touch and Swipe Baby Phone Screen Alignment: adım 4, 2 resimden 1. Repairing VTech Touch and Swipe Baby Phone Screen Alignment, Repairing VTech Touch and Swipe Baby Phone Screen Alignment: adım 4, 2 resimden 2.
      • Remove four 13.8mm screws from the back of the device using a Phillips #1 screwdriver.
      FixBot'a Sor
      Yorum Ekle
    2. Repairing VTech Touch and Swipe Baby Phone Screen Alignment: adım 5, 3 resimden 1. Repairing VTech Touch and Swipe Baby Phone Screen Alignment: adım 5, 3 resimden 2. Repairing VTech Touch and Swipe Baby Phone Screen Alignment: adım 5, 3 resimden 3.
      • Remove a single 4.8 mm screw with a Phillips #0 screwdriver and lift away the battery pack being careful of the wires.
      FixBot'a Sor
      Yorum Ekle
    3. Repairing VTech Touch and Swipe Baby Phone Screen Alignment: adım 6, 2 resimden 1. Repairing VTech Touch and Swipe Baby Phone Screen Alignment: adım 6, 2 resimden 2.
      • Remove two 7.2 mm screws with a Phillips #0 screwdriver.
      • Slide off the spring.
      FixBot'a Sor
      Yorum Ekle
    4. Repairing VTech Touch and Swipe Baby Phone Screen Alignment: adım 7, 3 resimden 1. Repairing VTech Touch and Swipe Baby Phone Screen Alignment: adım 7, 3 resimden 2. Repairing VTech Touch and Swipe Baby Phone Screen Alignment: adım 7, 3 resimden 3.
      • Remove the single 7.5mm screw with a Phillips #0 screwdriver.
      • Lift up the black plastic piece.
      FixBot'a Sor
      Yorum Ekle
    5. Repairing VTech Touch and Swipe Baby Phone Screen Alignment: adım 8, 2 resimden 1. Repairing VTech Touch and Swipe Baby Phone Screen Alignment: adım 8, 2 resimden 2.
      • Remove four 7.5mm screws with a Phillips #0 screwdriver.
      FixBot'a Sor
      Yorum Ekle
    6. Repairing VTech Touch and Swipe Baby Phone Screen Alignment: adım 9, 2 resimden 1. Repairing VTech Touch and Swipe Baby Phone Screen Alignment: adım 9, 2 resimden 2.
      • Remove the two buttons, noting how wires are placed for reassembly.
      FixBot'a Sor
      Yorum Ekle
    7. Repairing VTech Touch and Swipe Baby Phone Screen Alignment: adım 10, 2 resimden 1. Repairing VTech Touch and Swipe Baby Phone Screen Alignment: adım 10, 2 resimden 2.
      • Lift the button board up and away to clear room for lifting the motherboard.
      • Tilt the assembly up but being wary that it is still attached to the front panel.
      FixBot'a Sor
      Yorum Ekle
    8. Repairing VTech Touch and Swipe Baby Phone Screen Alignment: adım 11, 1 resimden 1.
      • Slide the toothed slider towards you to remove.
      FixBot'a Sor
      Yorum Ekle
    9. Repairing VTech Touch and Swipe Baby Phone Screen Alignment: adım 12, 1 resimden 1.
      • To reassemble, align the two black lines together by moving the belt back and forth.
      • Once aligned reinsert the toothed slider at the exact point shown.
      FixBot'a Sor
      Yorum Ekle
Sonuç
To reassemble your device, follow these instructions in reverse order, skipping step 10 as the toothed slider has already been put in for proper alignment.
Bir başkası bu kılavuzu tamamladı.
Sean Webb
384 İtibar
2 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 2-4, Sullivan Fall 2015 USF Tampa, Team 2-4, Sullivan Fall 2015 üyesi
USFT-SULLIVAN-F15S2G4
3 Üyeler
30 adet Kılavuz yazıldı
1Rehber Yorum
Good work !
Nice.
I did not see the black line in mine,
i opened the foil and glued it new together . Not so nice. :D
But it works.
Schwarzstein - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 6
Son 30 gün: 38
Her zaman: 1,959
