Ana içeriğe geç
Repairing Vizio Television Cable Connection
Neye ihtiyacın var
  1. Repairing Vizio Television  Cable Connection, Repairing Vizio Television  Cable Connection: adım 1, 1 resimden 1.
    • First, remove the (20) Phillips screws from the back plate. If your television is mounted against a wall, you'll have to remove it from your wall mounting bracket as well.
    • Don't forget the 2 Phillips screws in the motherboard area (circled in red).
    FixBot'a Sor
    Yorum Ekle
  2. Repairing Vizio Television  Cable Connection: adım 2, 3 resimden 1. Repairing Vizio Television  Cable Connection: adım 2, 3 resimden 2. Repairing Vizio Television  Cable Connection: adım 2, 3 resimden 3.
    • After removing the back plate, you'll see some circuit boards. We'll be focusing on the motherboard to the right.
    • (2) Phillips screws hold down covers over your inputs.
    • Note this screw holds down both covers where they overlap.
    • The bottom cover will not move until the 2 small Phillips screws are removed.
    FixBot'a Sor
    Yorum Ekle
  3. Repairing Vizio Television  Cable Connection: adım 3, 2 resimden 1. Repairing Vizio Television  Cable Connection: adım 3, 2 resimden 2.
    • Once the covers are all removed, you'll see a big hole where the cable connection is supposed to be.
    • Proceed to solder your new connection in like I did here. If you decide to replace the entire part you'll need to remove the motherboard... We'll save that for a different thread.
    FixBot'a Sor
    Yorum Ekle
  4. Repairing Vizio Television  Cable Connection: adım 4, 1 resimden 1.
    • You can then put it all back together once again in reverse order and enjoy some cable TV!
    FixBot'a Sor
    Yorum Ekle
Sonuç
14 farklı kişi bu kılavuzu tamamladı.
Ricky
867 İtibar
3 adet Kılavuz yazıldı
Ekip
TechTucson WeFixThat TechTucson WeFixThat üyesi
Community
2 Üyeler
4 adet Kılavuz yazıldı
7Kılavuz Yorumları
Are there pics of what needs to be done in order to solder the cable connector correctly?
MistaRite145 - Yanıt Paylaş
how can I order the part to repair the coax connector for the Vizio 32 inch tv
Steven William Schwenn - Yanıt Paylaş
how can I order the coax connector part to repair my 32 inch. Vizio TV.
WHAT part is the actual connector? Ive searched for days with NO LUCK! Its a rear mount cam twist thing;I can NOT find this part!!!!
john kowalski - Yanıt Paylaş
My vizio tv is not functioning properly. When i switch it on. The dispaly say. The tuner is not set up. Click Menu so set it up. Then, when i click the “Menu” may lumalabas na “HDTV setting”. When i click it. It will just go back to its normal form.
jpfernandez211 - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 15
Son 30 gün: 78
Her zaman: 18,824
