Ana içeriğe geç
Repairing a Clogged MakerBot Smart Extruder+
Neye ihtiyacın var
  1. Repairing a Clogged MakerBot Smart Extruder+, Repairing a Clogged MakerBot Smart Extruder+: adım 1, 1 resimden 1.
    • Place the extruder on a flat surface with the connection pins facing up.
  2. Repairing a Clogged MakerBot Smart Extruder+: adım 2, 1 resimden 1.
    • Remove the 4 screws on the outer edge of the extruder using the 2 mm hex wrench.
  3. Repairing a Clogged MakerBot Smart Extruder+: adım 3, 2 resimden 1. Repairing a Clogged MakerBot Smart Extruder+: adım 3, 2 resimden 2.
    • Remove the fan shroud from the extruder.
  4. Repairing a Clogged MakerBot Smart Extruder+: adım 4, 2 resimden 1. Repairing a Clogged MakerBot Smart Extruder+: adım 4, 2 resimden 2.
    • Turn the extruder on its side and cut through the black seal using the X-ACTO Knife.
  5. Repairing a Clogged MakerBot Smart Extruder+: adım 5, 2 resimden 1. Repairing a Clogged MakerBot Smart Extruder+: adım 5, 2 resimden 2.
    • Gently pull the two halves of the extruder apart.
  6. Repairing a Clogged MakerBot Smart Extruder+: adım 6, 3 resimden 1. Repairing a Clogged MakerBot Smart Extruder+: adım 6, 3 resimden 2. Repairing a Clogged MakerBot Smart Extruder+: adım 6, 3 resimden 3.
    • Remove the bearing and the hobbed bolt.
  7. Repairing a Clogged MakerBot Smart Extruder+: adım 7, 3 resimden 1. Repairing a Clogged MakerBot Smart Extruder+: adım 7, 3 resimden 2. Repairing a Clogged MakerBot Smart Extruder+: adım 7, 3 resimden 3.
    • Remove the freed nozzle and use needle nose pliers to pull out the filament that is clogging the extruder.
Sonuç
Aidan Tadeo
151 İtibar
1 Kılavuz yazıldı
Ekip
UC Davis, Team 1-6, Morris Winter 2023 UC Davis, Team 1-6, Morris Winter 2023 üyesi
UCD-MORRIS-W23S1G6
2 Üyeler
2 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 14
Son 30 gün: 41
Her zaman: 1,193
