Ana içeriğe geç
Repairing a Dried-Out Sharpie Marker
Neye ihtiyacın var
  1. Repairing a Dried-Out Sharpie Marker, Repairing a Dried-Out Sharpie Marker: adım 1, 2 resimden 1. Repairing a Dried-Out Sharpie Marker, Repairing a Dried-Out Sharpie Marker: adım 1, 2 resimden 2.
    • Remove the cap of the Sharpie.
  2. Repairing a Dried-Out Sharpie Marker: adım 2, 3 resimden 1. Repairing a Dried-Out Sharpie Marker: adım 2, 3 resimden 2. Repairing a Dried-Out Sharpie Marker: adım 2, 3 resimden 3.
    • Use a pair of pliers to separate the black part from the grey part of the Sharpie.
    • This can be a little difficult, so you may need to use two pairs of pliers to pull them apart.
  3. Repairing a Dried-Out Sharpie Marker: adım 3, 2 resimden 1. Repairing a Dried-Out Sharpie Marker: adım 3, 2 resimden 2.
    • Pull out the ink pad.
    • Only touch the sides of the ink pad so that you do not get ink on yourself.
  4. Repairing a Dried-Out Sharpie Marker: adım 4, 2 resimden 1. Repairing a Dried-Out Sharpie Marker: adım 4, 2 resimden 2.
    • Draw the rubbing alcohol into the syringe.
  5. Repairing a Dried-Out Sharpie Marker: adım 5, 3 resimden 1. Repairing a Dried-Out Sharpie Marker: adım 5, 3 resimden 2. Repairing a Dried-Out Sharpie Marker: adım 5, 3 resimden 3.
    • Drip the rubbing alcohol into the part of the ink pad that has a sponge with a hole in its center. Do this until the sponge seems saturated (or about 5 drops).
  6. Repairing a Dried-Out Sharpie Marker: adım 6, 2 resimden 1. Repairing a Dried-Out Sharpie Marker: adım 6, 2 resimden 2.
    • Put the ink pad back in.
  7. Repairing a Dried-Out Sharpie Marker: adım 7, 3 resimden 1. Repairing a Dried-Out Sharpie Marker: adım 7, 3 resimden 2. Repairing a Dried-Out Sharpie Marker: adım 7, 3 resimden 3.
    • Put the black part and grey part of the Sharpie back together.
  8. Repairing a Dried-Out Sharpie Marker: adım 8, 2 resimden 1. Repairing a Dried-Out Sharpie Marker: adım 8, 2 resimden 2.
    • Put the cap of the Sharpie back on.
  9. Repairing a Dried-Out Sharpie Marker: adım 9, 1 resimden 1.
    • Let the Sharpie set for 1-3 minutes.
Bitiş Çizgisi
Bir başkası bu kılavuzu tamamladı.
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 8
Son 7 gün: 13
Son 30 gün: 55
Her zaman: 486
