Giriş
In this guide, you will learn how to fix a loose pan handle. This will be done by removing the handle, cleaning the handle base, and repairing any warps. A warp is when the metal bends out of shape. This does not work on cast iron, since the handle does not come off.
Neye ihtiyacın var
Identify the screw keeping the handle in place.
Use a standard Phillips screwdriver to remove the screw(s).
Determine what kind of cleaning is required. I used a Lysol solution, which can be substituted with soap and water.
Apply your cleaning solution to the base.
If necessary, apply cleaning solution to the handle and metal bar, as well.
Wipe the area until it is clean, repeat if necessary.
Repeat this for any number of pans.
5 farklı kişi bu kılavuzu tamamladı.
