Ana içeriğe geç
Repairing a Panasonic SA-HT810V with the H02/H07 error
Neye ihtiyacın var
  1. Repairing a Panasonic SA-HT810V with the H02/H07 error, Repairing a Panasonic SA-HT810V with the H02/H07 error: adım 1, 3 resimden 1. Repairing a Panasonic SA-HT810V with the H02/H07 error, Repairing a Panasonic SA-HT810V with the H02/H07 error: adım 1, 3 resimden 2. Repairing a Panasonic SA-HT810V with the H02/H07 error, Repairing a Panasonic SA-HT810V with the H02/H07 error: adım 1, 3 resimden 3.
    • With the front display of the device facing you, rotate the device 90 degrees counter clockwise.
    • Remove the screw that is on the right side of the panel facing you.
    • Now rotate the device 180 degrees and remove the second screw.
    • Remove all screws with a phillips head screwdriver.
  2. Repairing a Panasonic SA-HT810V with the H02/H07 error: adım 2, 2 resimden 1. Repairing a Panasonic SA-HT810V with the H02/H07 error: adım 2, 2 resimden 2.
    • Rotate the device so that the back faces you.
    • With a phillips head screwdriver, locate and remove the two screws highlighted by the red circles in image one.
  3. Repairing a Panasonic SA-HT810V with the H02/H07 error: adım 3, 1 resimden 1.
    • Before removing top cover make sure that the back of the device is facing you.
    • Remove the top cover by bending out on the sides, and pulling the cover towards you while applying upward pressure.
  4. Repairing a Panasonic SA-HT810V with the H02/H07 error: adım 4, 2 resimden 1. Repairing a Panasonic SA-HT810V with the H02/H07 error: adım 4, 2 resimden 2.
    • Note that the spindle you will be lubing is located underneath the white disk device highlighted in figure one
    • Tilt the device on its front side until you can see underneath the white circular component mentioned in the note above.
    • Locate the spindle circled in figure two and apply one or two drops of 3 in 1 lubricating oil to the spindle.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Nathan Cheadle
161 İtibar
7 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 16-5, Maness Spring 2010 Cal Poly, Team 16-5, Maness Spring 2010 üyesi
CPSU-MANESS-S10S16G5
4 Üyeler
3 Yorum
Thanks you saved my Christmas and nailed this as my wife loves Christmas music in the background for our family dinner. Thanks again and Merry Christmas
Jerry Wayock - Yanıt
I have a Panasonic NV-SD235 and I have a tape stuck with the error H02.
Mark Zarraonandia - Yanıt
Can’t get screws undone on ours… Help!
Matthew - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 6
Son 30 gün: 55
Her zaman: 28,069
