Ana içeriğe geç
Eşyalarını Tamir Et
Onarma Hakkı
Parçalar ve Aletler
Giriş
This guide describes how to fix the H02/H07 error that is common with Panasonic DVD/VCR players.
Parçalar
Hiçbir parça belirtilmedi.
  1. With the front display of the device facing you, rotate the device 90 degrees counter clockwise. Remove the screw that is on the right side of the panel facing you. Now rotate the device 180 degrees and remove the second screw.
    • With the front display of the device facing you, rotate the device 90 degrees counter clockwise.
    • Remove the screw that is on the right side of the panel facing you.
    • Now rotate the device 180 degrees and remove the second screw.
    • Remove all screws with a phillips head screwdriver.
  2. Rotate the device so that the back faces you. With a phillips head screwdriver, locate and remove the two screws highlighted by the red circles in image one.
    • Rotate the device so that the back faces you.
    • With a phillips head screwdriver, locate and remove the two screws highlighted by the red circles in image one.
  3. Before removing top cover make sure that the back of the device is facing you.
    • Before removing top cover make sure that the back of the device is facing you.
    • Remove the top cover by bending out on the sides, and pulling the cover towards you while applying upward pressure.
  4. Note that the spindle you will be lubing is located underneath the white disk device highlighted in figure one Tilt the device on its front side until you can see underneath the white circular component mentioned in the note above.
    • Note that the spindle you will be lubing is located underneath the white disk device highlighted in figure one
    • Tilt the device on its front side until you can see underneath the white circular component mentioned in the note above.
    • Locate the spindle circled in figure two and apply one or two drops of 3 in 1 lubricating oil to the spindle.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Nathan Cheadle
137 İtibar
7 adet Kılavuz yazıldı
Takım
Cal Poly, Team 16-5, Maness Spring 2010 Cal Poly, Team 16-5, Maness Spring 2010 üyesi
CPSU-MANESS-S10S16G5
4 Üyeler
2 Yorum
Thanks you saved my Christmas and nailed this as my wife loves Christmas music in the background for our family dinner. Thanks again and Merry Christmas
Jerry Wayock - Yanıt
I have a Panasonic NV-SD235 and I have a tape stuck with the error H02.
Mark Zarraonandia - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 25
Son 30 gün: 124
Her zaman: 24,103
