Ana içeriğe geç
Repairing a Sliding Closet Door
Neye ihtiyacın var
  1. Repairing a Sliding Closet Door, Repairing a Sliding Closet Door: adım 1, 2 resimden 1. Repairing a Sliding Closet Door, Repairing a Sliding Closet Door: adım 1, 2 resimden 2.
    • Remove the screw on the top right side of the closet door that is not functioning correctly. Use a Phillips head screwdriver and rotate the screw counter clockwise until it falls out. You might want to use a stepladder to do this if you can't reach easily.
    • Reminder Be sure to put the screws where you can find them again! I suggest using a bowl or a cup. You will need the screws again later.
    • Do the same to the top left side of the closet door.
  2. Repairing a Sliding Closet Door: adım 2, 1 resimden 1.
    • Grab the door and pull up first then towards yourself.
    • Lean the door against a wall.
  3. Repairing a Sliding Closet Door: adım 3, 2 resimden 1. Repairing a Sliding Closet Door: adım 3, 2 resimden 2.
    • Run screw driver through the bottom track to clear any debris.
    • Spray a mixture of WD-40 and cleaning solution onto a clean rag.
    • Wipe down the track with the rag.
  4. Repairing a Sliding Closet Door: adım 4, 3 resimden 1. Repairing a Sliding Closet Door: adım 4, 3 resimden 2. Repairing a Sliding Closet Door: adım 4, 3 resimden 3.
    • Locate the 2 rollers hanging from the top track.
    • Pull the 2 rollers to the opposite ends of the track.
    • Push the roller up and away from yourself and it should come right off. Repeat this process for the other roller.
  5. Repairing a Sliding Closet Door: adım 5, 1 resimden 1.
    • Inspect both rollers making sure neither are broken.
    • Replace the broken roller if necessary.
    • Spray the entirety of the roller with WD-40.
  6. Repairing a Sliding Closet Door: adım 6, 1 resimden 1.
    • Put both rollers back on top track using the same method you used to get them off.
    • Note Make sure the flat part of the roller is facing the outside for both rollers.
  7. Repairing a Sliding Closet Door: adım 7, 2 resimden 1. Repairing a Sliding Closet Door: adım 7, 2 resimden 2.
    • Have a friend hold up closet door while you align rollers with the slots of the closet door.
    • Once the rollers are aligned, help your friend carefully slide the rollers back into the door.
    • Note Use the second picture of this step as a reference on how to slide the rollers back into the door.
  8. Repairing a Sliding Closet Door: adım 8, 2 resimden 1. Repairing a Sliding Closet Door: adım 8, 2 resimden 2.
    • Screw the the 2 screws you took out in step 1 back in.
    • Turn the screws clockwise to tighten
Bitiş Çizgisi
Glenn Farina
165 İtibar
1 Kılavuz yazıldı
Ekip
Cal Poly, Team 24-2, Green Winter 2015 Cal Poly, Team 24-2, Green Winter 2015 üyesi
CPSU-GREEN-W15S24G2
4 Üyeler
4 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 9
Son 30 gün: 29
Her zaman: 13,843
