Ana içeriğe geç
Repairing a Stuck Flint Wheel on a Zippo Lighter
Neye ihtiyacın var
  1. Repairing a Stuck Flint Wheel on a Zippo Lighter, Repairing a Stuck Flint Wheel on a Zippo Lighter: adım 1, 1 resimden 1.
    • Open your Zippo lighter and take the inside component out of the shell simply by pulling it out.
    • Be careful of the fluid that already might be in the lighter, it might leak out.
  2. Repairing a Stuck Flint Wheel on a Zippo Lighter: adım 2, 1 resimden 1.
    • Flip the lighter to face the bottom of the unit and locate the brass colored screw.
  3. Repairing a Stuck Flint Wheel on a Zippo Lighter: adım 3, 3 resimden 1. Repairing a Stuck Flint Wheel on a Zippo Lighter: adım 3, 3 resimden 2. Repairing a Stuck Flint Wheel on a Zippo Lighter: adım 3, 3 resimden 3.
    • Loosen the brass screw with the flat head screwdriver
    • Unscrew the rest of the brass screw using your hand.
    • Unscrew the brass screw until it comes off and the spring beneath shows but do not take the spring all the way out.
  4. Repairing a Stuck Flint Wheel on a Zippo Lighter: adım 4, 1 resimden 1.
    • Pull the brass screw and spring out about a centimeter or two to unhinge the steel rod located beneath the flint wheel so that the rod and the wheel are not touching.
    • If necessary, tap the unit to unhinge the steel rod
  5. Repairing a Stuck Flint Wheel on a Zippo Lighter: adım 5, 1 resimden 1.
    • Follow the steps backwards to reassemble the unit and check to see if the flint wheel is unstuck.
Sonuç
You have now fixed your flint wheel! Enjoy your Zippo Lighter!
32 farklı kişi bu kılavuzu tamamladı.
Joseph Yoo
983 İtibar
1 Kılavuz yazıldı
Ekip
Cal Poly, Team 28-3, Green Spring 2015 Cal Poly, Team 28-3, Green Spring 2015 üyesi
CPSU-GREEN-S15S28G3
4 Üyeler
8 adet Kılavuz yazıldı
29 Yorum
This made the problem even worse. The flint wheel is now unstuck but it can't make any sparks whatsoever.
Nabiel Wahedi - Yanıt
me too it will not work i did the same and now it wont make sparks
cool kid -
Did you change the flint aswell? Change the flint and put it back together, if it won’t turn after changing the flint then loosen the spring again.
Bret lauk -
You need to replace the flint itself in that case.
jayanthkumarak - Yanıt
Wonderful instructions! AND IT WORKED! Thank you.
John Heard - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 47
Son 7 gün: 296
Son 30 gün: 1,202
Her zaman: 145,488
