Ana içeriğe geç
Repairing a Wobbly Piano Bench
Neye ihtiyacın var
  1. Repairing a Wobbly Piano Bench, Repairing a Wobbly Piano Bench: adım 1, 1 resimden 1.
    • Place the bench on an even surface.
  2. Repairing a Wobbly Piano Bench: adım 2, 1 resimden 1.
    • Open and lock its lid. Make sure it stays open during the whole procedure.
  3. Repairing a Wobbly Piano Bench: adım 3, 3 resimden 1. Repairing a Wobbly Piano Bench: adım 3, 3 resimden 2. Repairing a Wobbly Piano Bench: adım 3, 3 resimden 3.
    • Unscrew the outer hex nut from one leg using the wrench and take the lock washer out.
  4. Repairing a Wobbly Piano Bench: adım 4, 3 resimden 1. Repairing a Wobbly Piano Bench: adım 4, 3 resimden 2. Repairing a Wobbly Piano Bench: adım 4, 3 resimden 3.
    • Take the leg out and unscrew the inner hex nut.
    • Replace the washers with the new ones and re-screw the hex nut tightly.
  5. Repairing a Wobbly Piano Bench: adım 5, 1 resimden 1.
    • Connect the leg to the bench again using the new lock washer.
    • Screw the hex nut a few rounds, but do not tighten it yet.
    • Repeat Steps 3 through 5 for all four legs.
  6. Repairing a Wobbly Piano Bench: adım 6, 2 resimden 1. Repairing a Wobbly Piano Bench: adım 6, 2 resimden 2.
    • Add a little weight to the chair or push it down with two hands.
    • Turn all four outer hex nuts one round.
    • Make sure the bench is balanced and repeat until all hex nuts are tight.
  7. Repairing a Wobbly Piano Bench: adım 7, 2 resimden 1. Repairing a Wobbly Piano Bench: adım 7, 2 resimden 2.
    • Close the lid seat on the chair.
    • If the chair is not balanced or if it makes noises, unscrew the outer nut two rounds and repeat Step 6.
Sonuç
You can redo this process every 6 months to make sure your bench is always stable.
Bir başkası bu kılavuzu tamamladı.
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 8
Son 30 gün: 27
Her zaman: 1,165
