Ana içeriğe geç
Giriş
Make sure to try these methods before using this guide:
1. Reset Network settings
2. Restart iPhone
3. Restore iPhone to factory settings
4. Go to Settings, Date and Time, change date and time to manual, and restart iPhone
5. Disconnect and reconnect the battery
If these procedures fail, proceed to the next section.
To make this guide, I tried to repair a common problem with the iPhone 4S. After using the freezer method and hairdryer method, the WiFi began working for briefly. I disassembled my iPhone, removed mother board, and used aluminium foil to protect it. I left only the WiFi chip unprotected. I used a heat-gun at 300 degrees to heat up the chip for 5 to 10 seconds and left it to cool down. I reassembled the iPhone and voila, it works.
  1. Insert wisdom here. Insert wisdom here.
    • Insert wisdom here.
Sonuç
36 farklı kişi bu kılavuzu tamamladı.
Mario
858 İtibar
1 Kılavuz yazıldı
10 Yorum
My iPhone is disabled
JeNai Jackson - Yanıt
How can I get it unlocked if I don't have a computer
JeNai Jackson -
Without using an computer to connect to iTunes
JeNai Jackson -
So how do I fix an iPhone that is completely disabled and you connect to iTunes but you can't turn off the Find my Iphone
Alexking - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 7
Son 7 Gün: 27
Son 30 Gün: 122
Her zaman: 28,362
