Ana içeriğe geç
Repairing nose pads on eyeglasses
Neye ihtiyacın var
  1. Repairing nose pads on eyeglasses, Repairing nose pads on eyeglasses: adım 1, 2 resimden 1. Repairing nose pads on eyeglasses, Repairing nose pads on eyeglasses: adım 1, 2 resimden 2.
    • Remove the screw from the pad arm.
    • If the screw is missing, get a backup screw, and proceed to step 2.
  2. Repairing nose pads on eyeglasses: adım 2, 2 resimden 1. Repairing nose pads on eyeglasses: adım 2, 2 resimden 2.
    • Insert the nose pad into the mount on the frame.
    • Make sure the nose pad lines up with the screw hole.
    • While holding the nose pad in place, use the magnet to attract the screw head.
    • Make sure the screw is vertical to the magnet and the screw head is above.
  3. Repairing nose pads on eyeglasses: adım 3, 1 resimden 1.
    • Place the screw into the screw hole.
  4. Repairing nose pads on eyeglasses: adım 4, 2 resimden 1. Repairing nose pads on eyeglasses: adım 4, 2 resimden 2.
    • Using a horizontal motion, remove the magnet.
    • Don't use a vertical motion to remove the magnet, otherwise the screw will come out.
  5. Repairing nose pads on eyeglasses: adım 5, 2 resimden 1. Repairing nose pads on eyeglasses: adım 5, 2 resimden 2.
    • Holding the glasses with the screw head pointing up, tighten the screw with the screwdriver.
    • Make sure the screw is tightened enough.
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Vivi Chou
151 İtibar
1 Kılavuz yazıldı
Ekip
UC Davis, Team S3-G4, Coad Spring 2017 UC Davis, Team S3-G4, Coad Spring 2017 üyesi
UCD-COAD-S17S3G4
3 Üyeler
3 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 9
Son 7 gün: 84
Son 30 gün: 251
Her zaman: 49,563
