Giriş
This guide will help you repair the buttons on the Seville Classics MSC10166 Tower Fan.
Aletler
Parçalar
Hiçbir parçaya gerek yok.
Use a Philips #2 screwdriver to unscrew the four 6mm Phillips #0 back screws.
Next remove the two (7-mm head) 8-mm screws that attach the buttons to the top cover of the fan.
2 başka kişi bu kılavuzu tamamladı.
Bir Yorum
Great work but our problem is the micro switch itself, after exposing the circuit board I shorted the backside solder connections to cycle the fan on and off, everything works perfectly…..now I only need to know a part number so I can find a on/off micro switch.
any suggestions?
Thanks for any help you can provide
rickkingsbury@comcast.net
