Ana içeriğe geç
Repairing/Cleaning LeapFrog LeapPad2 Explorer IN 4 STEPS
Arşivlenmiş Kılavuz
Bu kılavuz sadece arşivsel amaçlarla muhafaza edilmiştir. Onarımınızı gerçekleştirmek için kılavuzun güncel halini kullanın.
Neye ihtiyacın var
  1. Repairing/Cleaning LeapFrog LeapPad2 Explorer IN 4 STEPS, Remove Back Panels: adım 1, 2 resimden 1. Repairing/Cleaning LeapFrog LeapPad2 Explorer IN 4 STEPS, Remove Back Panels: adım 1, 2 resimden 2.
    • Remove back panels by applying pressure and slide outwards. Check to see if there are batteries or if they need replacing.
  2. Repairing/Cleaning LeapFrog LeapPad2 Explorer IN 4 STEPS, Remove Back Panel: adım 2, 2 resimden 1. Repairing/Cleaning LeapFrog LeapPad2 Explorer IN 4 STEPS, Remove Back Panel: adım 2, 2 resimden 2.
    • Begin removing screws from back panel. There should be of 8 screws all together. Be sure not to lose them after removing! Also separate the outer screws and the inner screws. The screws are two different sizes so don't mix them up.
  3. Repairing/Cleaning LeapFrog LeapPad2 Explorer IN 4 STEPS, Cleaning Time: adım 3, 2 resimden 1. Repairing/Cleaning LeapFrog LeapPad2 Explorer IN 4 STEPS, Cleaning Time: adım 3, 2 resimden 2.
    • Carefully clean around the circuit board with cloth. Then brush the inside of the outer shell and wipe it down with the cloth as well. Be careful not to disconnect the wires. Carefully replace the circuit board and close the shell. Rescrew the screws, make sure the correct ones are entered into the correct slot.
  4. Repairing/Cleaning LeapFrog LeapPad2 Explorer IN 4 STEPS, Clean Screen!: adım 4, 1 resimden 1.
    Bu adımda kullanılan alet:
    Microfiber Cleaning Cloths
    $3.99
    Satın Al
    • Spray a small amount of applejuice brand spray (screen cleaner) and use micro fiber cloth and wipe back and forth until the screen is clean.
  5. Repairing/Cleaning LeapFrog LeapPad2 Explorer IN 4 STEPS, Ta Da!: adım 5, 2 resimden 1. Repairing/Cleaning LeapFrog LeapPad2 Explorer IN 4 STEPS, Ta Da!: adım 5, 2 resimden 2.
    • Ta Da! Your device is now cleaned and has been checked. Try to power on, hopefully your leap pad will function correctly. If not, please contact Leap Frog Co. directly.
Sonuç
Lauren
1 İtibar
1 Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 0
Her zaman: 613
