Ana içeriğe geç
Replace Apple Xserve 2009 Motherboard and fans
Neye ihtiyacın var
  1. Replace Apple Xserve 2009 Motherboard and fans, Xserve 2009 MLB and Fan replacement: adım 1, 2 resimden 1. Replace Apple Xserve 2009 Motherboard and fans, Xserve 2009 MLB and Fan replacement: adım 1, 2 resimden 2.
    • Notable specs:
    • Dual Xeon Nehalem CPU @ 2.26 GHz
    • No SSD
    • No Hardware RAID
  2. Replace Apple Xserve 2009 Motherboard and fans: adım 2, 1 resimden 1.
    • Pull on release lever, and pull power supply out.
  3. Replace Apple Xserve 2009 Motherboard and fans: adım 3, 2 resimden 1. Replace Apple Xserve 2009 Motherboard and fans: adım 3, 2 resimden 2.
    • Loosen the 2 thumbscrews on the back of the xserve to release the top.
    • Slide top back, and lift top off.
  4. Replace Apple Xserve 2009 Motherboard and fans: adım 4, 1 resimden 1.
    • This step is not necessary if you are not changing the drive. It does not interfere with the rest of the procedure.
    • If the hard drives or blanks are still in the xserve, push the handle in to pop it out.
    • Pull the hard drive and blank sleds out.
  5. Replace Apple Xserve 2009 Motherboard and fans: adım 5, 3 resimden 1. Replace Apple Xserve 2009 Motherboard and fans: adım 5, 3 resimden 2. Replace Apple Xserve 2009 Motherboard and fans: adım 5, 3 resimden 3.
    • Slide lever lock to release the CD/DVD drive.
    • Slide CD/DVD drive back.
    • Lift drive up and unplug the SATA connector on the back.
  6. Replace Apple Xserve 2009 Motherboard and fans: adım 6, 1 resimden 1.
    • Using a #1 Phillips screwdriver, unscrew the screws on each side of PCI slot #2 on the back of the computer.
    • Once the screws are loosened, the PCI riser card should lift out of the slot.
    • Repeat for PCI slot #1
  7. Replace Apple Xserve 2009 Motherboard and fans: adım 7, 1 resimden 1.
    • Remove the RAM from all slots.
  8. Replace Apple Xserve 2009 Motherboard and fans: adım 8, 2 resimden 1. Replace Apple Xserve 2009 Motherboard and fans: adım 8, 2 resimden 2.
    • Using a 3.0mm Hex wrench (Allen wrench), loosen the 4 screws that hold the processor and heatsink down.
    • Unplug the sensor cable.
    • Lift the heatsink and processor off the motherboard.
    • Repeat if you have the dual processor model.
  9. Replace Apple Xserve 2009 Motherboard and fans: adım 9, 3 resimden 1. Replace Apple Xserve 2009 Motherboard and fans: adım 9, 3 resimden 2. Replace Apple Xserve 2009 Motherboard and fans: adım 9, 3 resimden 3.
    • Using a #1 phillips screwdriver, loosen the 5 screws that hold the plastic bezel in place.
    • Remove the plastic bezel.
    • Using a #2 phillips screwdriver, loosen the 2 screws that hold the fan array in place
    • Lift the fan array out.
  10. Replace Apple Xserve 2009 Motherboard and fans: adım 10, 2 resimden 1. Replace Apple Xserve 2009 Motherboard and fans: adım 10, 2 resimden 2.
    • Using the spudger, lift the connector on the right.
    • Carefully squeeze the connector on the left and unplug it.
    • Using the spudger, lift the CD/DVD connector by the CPU A RAM slots.
  11. Replace Apple Xserve 2009 Motherboard and fans: adım 11, 3 resimden 1. Replace Apple Xserve 2009 Motherboard and fans: adım 11, 3 resimden 2. Replace Apple Xserve 2009 Motherboard and fans: adım 11, 3 resimden 3.
    • Using a #2 screwdriver, loosen the 9 screws that hold the motherboard in place.
    • There are 3 rows of 3 screws each. 1 row by the back of the computer, 1 row in the middle and 1 row by the fan array. They are obvious by the black plastic spacer/retainer on them.
  12. Replace Apple Xserve 2009 Motherboard and fans: adım 12, 1 resimden 1.
    • Using a #2 screwdriver, loosen the screw on the power board.
    • Slide it up to disconnect it from the motherboard.
  13. Replace Apple Xserve 2009 Motherboard and fans: adım 13, 2 resimden 1. Replace Apple Xserve 2009 Motherboard and fans: adım 13, 2 resimden 2.
    • Remove the 2 screws that hold the video card on.
    • Slide the card out of the socket.
  14. Replace Apple Xserve 2009 Motherboard and fans: adım 14, 1 resimden 1.
    • Lift the motherboard and slide it out ofthe connectors on the back of the computer.
    • Then tip the motherboard up and out of the computer.
Sonuç
18 farklı kişi bu kılavuzu tamamladı.
Tod Hallberg
677 İtibar
1 Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 6
Son 30 gün: 49
Her zaman: 11,817
