Giriş
This CPU doesn't have the same graphics card as the disassembly tutorial. In the latter, the graphics card is a reduced format. However, full-size graphics cards are usually accompanied by a guide to prevent physical damage to the card or motherboard port.
This guide, screwed to the graphics card, makes installing or removing a graphics card more delicate. That's why this replacement tutorial will also include steps for reinstalling such a graphics card.
There's also a step-by-step guide to show which graphics cards are compatible with this model in terms of size.
First, pull the handle and raise the upper part of the case.
After taking the upper part off, you'll see the covers of the different pieces of the PC.
The GPU has a guide. It's necessary to pay attention and don't forget about it while taking the GPU off.
Disconnect the power connector from the GPU.
You can clip the connectors in a specifically designed place.
Raise the rod that maintains the PCI GPU in place.
Raise the tab that maintains the GPU in its port.
Raise the GPU slowly from the side of the guide until the GPU partially comes out of its port.
Raise the GPU from its other side.
Introduce the new GPU at 45º from the motherboard.
Place the guide in front of the appropriate slot and push the graphics card into it, making sure it fits into its PCI slot.
To check that your graphics card is correctly installed, check that the tab is properly locked in place.
Insert the graphics card into the PCI bracket until it clicks into place.
Don't forget to connect the power supply connectors to the GPU if it's necessary.
The Sapphire RX 5700XT GPU is the largest card that fits in the case without problems.
As it's already explained, the case has special spots for clipping the unused power supply ports.
The reinstallation stages are included in the tutorial.
Bir başkası bu kılavuzu tamamladı.
Bu çevirmenlere özel teşekkürler:
100%
Bu çevirmenler dünyayı onarmamıza yardım ediyor! Katkıda bulunmak ister misiniz?
Çeviriye Başlayın ›
