Ana içeriğe geç
Eşyalarını Tamir Et
Onarma Hakkı
Mağaza
Parçalar
Hiçbir parça belirtilmedi.
  1. Open the latch on the right side that secures the battery in place. Open the latch on the left side that secures the battery in place. Now remove the battery.
    • Open the latch on the right side that secures the battery in place.
    • Open the latch on the left side that secures the battery in place.
    • Now remove the battery.
  2. Carefully slide the nail between the frame and the glass of the screen. First clip off the mounting points of the LCD screen frame. First clip off the mounting points of the LCD screen frame.
    • Carefully slide the nail between the frame and the glass of the screen.
    • First clip off the mounting points of the LCD screen frame.
  3. TÜM SEKMELERİ AÇ
    Mac için RAM Yükseltme Kit'leri
    Kit Satın Al
    Tüm Sekmeler İçin Yeterli RAM
    Kit Satın Al
  4. Free the LCD screen frame completely. Locate and loosen the two upper mounting screws of the LCD screen. Locate and loosen the two lower mounting screws of the LCD screen.
    • Free the LCD screen frame completely.
    • Locate and loosen the two upper mounting screws of the LCD screen.
    • Locate and loosen the two lower mounting screws of the LCD screen.
  5. Carefully place the LCD screen on the keyboard. Locate the plug of the LCD screen. Free the fixing cable.
    • Carefully place the LCD screen on the keyboard.
    • Locate the plug of the LCD screen.
    • Free the fixing cable.
  6. Disconnect the cable from its plug. Then lift out the LCD screen.
    • Disconnect the cable from its plug.
    • Then lift out the LCD screen.
Sonuç
To assemble the device again, proceed in reverse order.
Bu çevirmenlere özel teşekkürler:
100%
irlanda dünyayı onarmamıza yardım ediyor! Katkıda bulunmak ister misiniz?
Çeviriye Başlayın ›
Felice Suglia
14.934 İtibar
150 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 6
Son 30 gün: 42
Her zaman: 392
