Ana içeriğe geç
Replace RAM memory from why! WDi7SSD
Neye ihtiyacın var
  1. Replace RAM memory from why! WDi7SSD, why! WDi7SSD Opening procedure: adım 1, 3 resimden 1. Replace RAM memory from why! WDi7SSD, why! WDi7SSD Opening procedure: adım 1, 3 resimden 2. Replace RAM memory from why! WDi7SSD, why! WDi7SSD Opening procedure: adım 1, 3 resimden 3.
    • Make sure the computer is disconnected from the power source.
    • Flip the computer over.
    • Remove the six screws with a 2 mm Allen key.
    • Carefully remove the back panel, as well the left and right panel.
  2. Replace RAM memory from why! WDi7SSD: adım 2, 1 resimden 1.
    • Now flip up the base panel to which all components are attached.
  3. Replace RAM memory from why! WDi7SSD, RAM memory: adım 3, 2 resimden 1. Replace RAM memory from why! WDi7SSD, RAM memory: adım 3, 2 resimden 2.
    • Disconnect the cable that goes over the RAM bars.
  4. Replace RAM memory from why! WDi7SSD: adım 4, 2 resimden 1. Replace RAM memory from why! WDi7SSD: adım 4, 2 resimden 2.
    • Press down the small metal springs on both sides and push them to the side.
    • The latch loosens and can be removed.
    • Perform both steps again to remove the second latch.
Sonuç
To reassemble the unit, follow the instructions in reverse order.
Bu çevirmenlere özel teşekkürler:
de en
100%
oldturkey03 dünyayı onarmamıza yardım ediyor! Katkıda bulunmak ister misiniz?
Çeviriye Başlayın ›
Felice Suglia
33.538 İtibar
283 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 1
Her zaman: 173
