Ana içeriğe geç
Eşyalarını Tamir Et
Onarma Hakkı
Mağaza
Parçalar
Hiçbir parça belirtilmedi.
  1. Open the latch on the right side that secures the battery in place. Open the latch on the left side that secures the battery in place. Now remove the battery.
    • Open the latch on the right side that secures the battery in place.
    • Open the latch on the left side that secures the battery in place.
    • Now remove the battery.
  2. Using a Philips-head screwdriver remove highlighted screws. Look at the marking to see how to remove the access cover. Remove the access cover as shown by the marker.
    • Using a Philips-head screwdriver remove highlighted screws.
    • Look at the marking to see how to remove the access cover.
    • Remove the access cover as shown by the marker.
  3. TÜM SEKMELERİ AÇ
    Mac için RAM Yükseltme Kit'leri
    Kit Satın Al
    Tüm Sekmeler İçin Yeterli RAM
    Kit Satın Al
  4. You now have access to all components of this laptop.
    • You now have access to all components of this laptop.
  5. Here is the chipset WLAN / Bluetooth. Carefully loosen the antenna plugs MAIN and AUX. Loosen the fixing screw with the Philips screwdriver.
    • Here is the chipset WLAN / Bluetooth.
    • Carefully loosen the antenna plugs MAIN and AUX.
    • Loosen the fixing screw with the Philips screwdriver.
  6. Lift the chipset a little and pull it out to the mSATA connector. Lift the chipset a little and pull it out to the mSATA connector.
    • Lift the chipset a little and pull it out to the mSATA connector.
Sonuç
To assemble the device again, proceed in reverse order.
Bu çevirmenlere özel teşekkürler:
100%
irlanda dünyayı onarmamıza yardım ediyor! Katkıda bulunmak ister misiniz?
Çeviriye Başlayın ›
Felice Suglia
14.934 İtibar
150 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 0
Her zaman: 57
