Ana içeriğe geç
Replace/overhaul support valve
Neye ihtiyacın var
  1. Replace/overhaul support valve, Support Valve: adım 1, 3 resimden 1. Replace/overhaul support valve, Support Valve: adım 1, 3 resimden 2. Replace/overhaul support valve, Support Valve: adım 1, 3 resimden 3.
    • If the brewing unit is still in the machine, remove it now.
    • The support valve will become visible. It is attached with two Torx T10 screws. Unscrew them.
    • Pull the support valve out towards you, using a little force and wiggling movements.
    • Pay attention to the seals: there is a double seal at the inlet, which may also get stuck in the opening. Replace it.
    • There are two seals at the outlet, with the larger one at the top. Replace them.
  2. Replace/overhaul support valve: adım 2, 1 resimden 1.
    • Turn the valve so that the top is facing you. You will see a slot. Take a flat screwdriver and turn it slightly counterclockwise.
    • Use some tweezers to carefully lift out the inside of the valve
  3. Replace/overhaul support valve: adım 3, 1 resimden 1.
    • The valve stem points upwards.
    • If the two green O-rings do no longer properly seal, the valve will no longer work. Replace the seals.
Sonuç
Follow the steps in reverse order to reassemble your device.
Bu çevirmenlere özel teşekkürler:
de en
100%
oldturkey03 dünyayı onarmamıza yardım ediyor! Katkıda bulunmak ister misiniz?
Çeviriye Başlayın ›
VauWeh
252.704 İtibar
286 adet Kılavuz yazıldı
Ekip
Repair is War on Entropy Repair is War on Entropy üyesi
Community
29 Üyeler
1.764 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 5
Son 7 gün: 53
Son 30 gün: 264
Her zaman: 1,361
