Ana içeriğe geç
Replacement Ram
Neye ihtiyacın var
  1. Replacement Ram, Ram: adım 1, 1 resimden 1.
    • Turn the laptop upside down. Locate a removable cover, that is screwed shut near the front right of the laptop which is upside down.
  2. Replacement Ram: adım 2, 1 resimden 1.
    • After removing the screw, using your finger slowly lift out and remove the cover.
  3. Replacement Ram: adım 3, 3 resimden 1. Replacement Ram: adım 3, 3 resimden 2. Replacement Ram: adım 3, 3 resimden 3.
    • Lift the flap
    • Locate two connectors on both ends of the short end. This will release the ram, if properly done the long end should slightly lift.
    • The ram is to be removed at a 45 degree angle.
  4. Replacement Ram: adım 4, 1 resimden 1.
    • Pull out cleanly and you have now successfully removed the ram.
Sonuç
Eric Martinez
637 İtibar
6 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 20-5, Remmell Spring 2017 USF Tampa, Team 20-5, Remmell Spring 2017 üyesi
USFT-REMMELL-S17S20G5
3 Üyeler
12 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 6
Her zaman: 361
