Ana içeriğe geç
Replacement de la vitre tactile et de l'écran LCD du Samsung Galaxy Note8
Neye ihtiyacın var
    • Insérer un commentaire.
Bitiş Çizgisi
21 farklı kişi bu kılavuzu tamamladı.
ian mdx
8.968 İtibar
17 adet Kılavuz yazıldı
9 Yorum
Am I to assume that I dont need to reapply or replace glue or adhesive strips? Is simply reheating the previous glue good enough to hold it?
Andrew Gross - Yanıt
You might get away with re-heating the previously used glue the first time, however you may also notice the screen lifting from the frame. I would suggest using 99% Isopropyl alcohol to remove any excess or poorly positioned glue remaining after removing the LCD and re-applying a small amount of E8000 around the edges where there is glue missing. Posting this answer very late, but only because I know people are still repairing the Note8 using similar guides because it’s how I got here.
Jack Donovan -
note8 siyah ekran bozuldu. fiyat nedir
yasin tufekci - Yanıt
Mine is coming up saying Note Network found after completion of the repair any ideas?
James Turner - Yanıt
Will the phone remain waterproof after this repair?
cj-dm - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 3
Her zaman: 24,032
