Giriş
Do you want to change your hard disk to increase its capacity or replace it, because it no longer works? Perfect, you've come to the right place, this tutorial is for you!
Neye ihtiyacın var
Pop the center cover open on the bottom cover.
Remove the center screw with a #00 Phillips screwdriver.
Use a T5 Torx screwdriver for the remaining screws around the edge of the bottom cover.
Once all the screws have been removed the battery is now safe to extract
Remove the screw with a #00 Phillips screwdriver.
Remove the hard disk from its location.
To reassemble your device, follow the instructions in reverse order.
2 farklı kişi bu kılavuzu tamamladı.
Bu çevirmenlere özel teşekkürler:
100%
Schwarzer dünyayı onarmamıza yardım ediyor! Katkıda bulunmak ister misiniz?
Çeviriye Başlayın ›
