Ana içeriğe geç
Replacing Antenna on Realistic Weatheradio
Neye ihtiyacın var
  1. Replacing Antenna on Realistic Weatheradio, Antenna: adım 1, 1 resimden 1.
    • To remove the back panel from the Weather radio, use your index finger and push down on the tab located on the back.
  2. Replacing Antenna on Realistic Weatheradio: adım 2, 1 resimden 1.
    • Use a Phillips 1X80 screwdriver to loosen the screw located on the bottom right of the back panel.
    • Do not attempt to remove the screw because it will not come out.
  3. Replacing Antenna on Realistic Weatheradio: adım 3, 2 resimden 1. Replacing Antenna on Realistic Weatheradio: adım 3, 2 resimden 2.
    • Once the screw is loose, slowly pull out the antenna until it is completely out.
    • Once the antenna is out, you can replace it with the new one.
    • Do not force the antenna inside and make sure it is coiled all the way down.
Sonuç
After following these steps, the Realistic Weatheradio should be able to work and function normally.
2 farklı kişi bu kılavuzu tamamladı.
Ekli Belgeler
Matthew
136 İtibar
1 Kılavuz yazıldı
Ekip
Texas Tech, Team 3-5, Rauch SU 2015 Texas Tech, Team 3-5, Rauch SU 2015 üyesi
TTU-RAUCH-SU15S3G5
3 Üyeler
1 Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 9
Son 30 gün: 25
Her zaman: 1,031
